16# if !defined(__INTIME__)
17# define HAS_CARTESIAN_ROBOT 1
21# define RSI_API __declspec(dllexport)
23# define RSI_API __declspec(dllimport)
26#elif defined(__linux__)
27# define HAS_CARTESIAN_ROBOT 1
29# define RSI_API __attribute__ ((visibility ("default")))
34#define PURE_VIRTUAL = 0
45 template<
typename Type>
48#if defined(__cplusplus)
58class RapidCodeNetworkNode;
63class StaticInstanceMediator
69 bool IsValid() {
return isValid; }
71 void OnDelete() { isValid =
false; }
73 void OnCreate() { isValid =
true; }
110class RsiError :
public std::exception
153#elif defined(__linux__)
169 virtual const char*
what() const noexcept {
return text; }
337 virtual
void Trace(
bool state) PURE_VIRTUAL;
513 virtual void Sleep(int32_t milliseconds) PURE_VIRTUAL;
533 virtual int32_t
KeyGet(int32_t milliseconds) PURE_VIRTUAL;
799 StaticInstanceMediator* _mediator;
954#elif defined(__linux__)
1029#if defined(_WIN32) && defined(__linux__)
1030 static_assert(
false,
"_WIN32 and __linux__ defined. Double check preprocessor definitions");
1031#elif !defined(_WIN32) && !defined(__linux__) && !defined(DOXYGEN)
1032 static_assert(
false,
"Neither _WIN32 nor __linux__ are defined AND this is not a documentation build. Double check preprocessor definitions");
1034#if defined(_WIN32) || defined(DOXYGEN)
1049#if defined(__linux__) || defined(DOXYGEN)
1127 static MotionController*
Get(
const char*
const nodeName);
1294 virtual IO*
IOGet(int32_t nodeNumber) PURE_VIRTUAL;
1606 virtual
void AxisCountSet(int32_t axisCount,
bool setMotorFilterSupervisor) PURE_VIRTUAL;
1875 virtual
void MemoryBlockGet(uint64_t address,
void* dataStart, int32_t size) PURE_VIRTUAL;
1891 virtual
void MemorySet(uint64_t address, int32_t data) PURE_VIRTUAL;
1938 virtual
void MemoryBlockSet(uint64_t address, const
void* const dataStart, int32_t size) PURE_VIRTUAL;
3800 virtual
void CompensatorConfigSet(int32_t compensatorNumber, int32_t firstInputAxisNumber,
RSIAxisMasterType firstInputAxisType,
double firstInputAxisMinimum,
double firstInputAxisMaximum,
double firstInputAxisDelta, int32_t secondInputAxisNumber,
RSIAxisMasterType secondInputAxisType,
double secondInputAxisMinimum,
double secondInputAxisMaximum,
double secondInputAxisDelta, int32_t outputAxisNumber,
RSICompensatorOutputType outputType, const
double* const table) PURE_VIRTUAL;
3831 virtual
Axis* firstInputAxis,
Axis* secondInputAxis,
Axis* outputAxis,
4144 virtual
void UserLimitOutputSet(int32_t number, uint32_t andMask, uint32_t orMask, uint64_t outputPtr,
bool enabled) PURE_VIRTUAL;
4148 virtual
void UserLimitOutputSet(int32_t number, int32_t valueSet, uint64_t outputPtr,
4152 virtual
void UserLimitOutputSet(int32_t number, uint64_t andMask, uint64_t orMask, uint64_t outputPtr,
4156 virtual
double limitValueDouble, uint64_t outputPtr,
4510 virtual
void AnalogOutSet(int32_t analogChannel, int32_t analogValue) PURE_VIRTUAL;
5844 virtual
void Map() PURE_VIRTUAL;
6786 virtual
void MovePT(
RSIMotionType type, const
double* const position, const
double* const time, int32_t pointCount, int32_t emptyCount,
bool retain,
bool final) PURE_VIRTUAL;
6825 virtual
void MovePVT(const
double* const velocity, const
bool retain,
6856 virtual
void MovePVAJT(const
double* const acceleration, const
double* const jerk, const
bool retain,
6894 virtual
void MovePTF(const
double* const time, const
double* const feedforward, int32_t pointCount, int32_t emptyCount,
bool retain,
6936 virtual
void MovePVTF(const
bool retain,
6971 virtual
void StreamingOutputAdd(int32_t onMask, int32_t offMask, uint64_t address, int32_t ptPointIndex) PURE_VIRTUAL;
7050 friend class MotionController;
7051 friend class MultiAxis;
7124 virtual void MoveTrapezoidal(
double position,
double vel,
double accel,
double decel) PURE_VIRTUAL;
7147 virtual void MoveTrapezoidal(
double position,
double vel,
double accel,
double decel,
double finalVel) PURE_VIRTUAL;
7181 virtual void MoveSCurve(
double position,
double vel,
double accel,
double decel,
double jerkPct) PURE_VIRTUAL;
7197 virtual void MoveSCurve(
double position,
double vel,
double accel,
double decel,
double jerkPct,
7320 virtual void MoveRelative(
double relativePosition,
double vel,
double accel,
double decel,
7335 virtual void MoveRelative(
double vel,
double accel,
double decel,
double jerkPct,
7795 virtual
void Home(
bool moveToZero = true) PURE_VIRTUAL;
11071 virtual
void GearingEnable(int32_t masterAxisNumber,
RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator) PURE_VIRTUAL;
11103 virtual
void GearingRatioChange(int32_t numerator, int32_t denominator) PURE_VIRTUAL;
11287 virtual
void MoveCamLinear(int32_t masterAxisNumber,
RSIAxisMasterType masterFeedbackSource, const
double* const masterDistances, const
double* const slavePositions, int32_t pointCount) PURE_VIRTUAL;
11318 virtual
void MoveCamCubic(int32_t masterAxisNumber,
double* const slavePositions, const
double* const gearRatios, int32_t pointCount) PURE_VIRTUAL;
11737 virtual
void PostFilterSingleOrderSet(int32_t sectionNumber,
double aOne,
double bZero,
double bOne) PURE_VIRTUAL;
11773 virtual
void PostFilterNotchSet(int32_t sectionNumber,
double centerFreq,
double bandwidth) PURE_VIRTUAL;
11793 virtual
void PostFilterResonatorSet(int32_t sectionNumber,
double centerFreq,
double bandwidth,
double gain) PURE_VIRTUAL;
11813 virtual
void PostFilterLeadLagSet(int32_t sectionNumber,
double lowGain,
double highGain,
double centerFreq) PURE_VIRTUAL;
11852 virtual
void PostFilterBiquadSet(int32_t sectionNumber,
double aOne,
double aTwo,
double bZero,
double bOne,
double bTwo) PURE_VIRTUAL;
11883 virtual const
char* const
UserLabelGet() PURE_VIRTUAL;
11905 virtual
void UserLabelSet(const
char* const userLabel) PURE_VIRTUAL;
12696 virtual
void PathArcAdd(const
double* const center,
double angle) PURE_VIRTUAL;
12757 virtual
void MoveTrapezoidal(const
double* const vel, const
double* const accel, const
double* const decel) PURE_VIRTUAL;
12792 virtual
void MoveSCurve(const
double* const decel, const
double* const jerkPct) PURE_VIRTUAL;
12810 virtual
double* const jerkPct, const
double* const finalVel) PURE_VIRTUAL;
12826 virtual
void MoveVelocity(const
double* const accel) PURE_VIRTUAL;
12854 virtual
void MoveRelative(const
double* const relativePosition, const
12872 virtual
12890 virtual
void MoveVelocitySCurve(const
13230 virtual
void Set(
13476 friend class MotionController;
13741 virtual
13764#if defined(__cplusplus)
13768template<
typename ContainerClass>
13769class RSI_API RapidVectorIterator
13773 typedef typename ContainerClass::ValueType ValueType;
13776 typedef typename ContainerClass::PointerType PointerType;
13780 ValueType& operator*();
13784 const ValueType& operator*()
const;
13788 RapidVectorIterator& operator++();
13792 RapidVectorIterator operator++(
int);
13796 bool operator==(
const RapidVectorIterator&)
const;
13800 bool operator!=(
const;
13803 RapidVectorIterator(PointerType pointerArgument, PointerType startArgument,
const size_t containerSize);
13806 RapidVectorIterator(
const RapidVectorIterator&) =
default;
13809 RapidVectorIterator& operator=(
default;
13812 RapidVectorIterator(RapidVectorIterator&&)
noexcept =
default;
13815 RapidVectorIterator& operator=(RapidVectorIterator&&)
noexcept =
default;
13817 PointerType pointer;
13818 PointerType start, end;
13819 void VerifyPointer()
const;
13823template<
typename Type>
13824class RapidVectorImplementation;
13841template<
typename Type>
13846 RapidVectorImplementation<Type>* pImpl;
13861 Type&
At(
const size_t index);
13866 const Type&
At(
const size_t index)
const;
13910#if defined(SWIG) && defined(__linux__)
13914#elif defined(_WIN32)
13915 template<
typename =
typename std::enable_if_t<std::is_default_constructible_v<Type>>>
13918 template<typename UType = Type, typename Enable = typename std::enable_if<std::is_default_constructible<UType>::value>::type>
13940 typedef Type* PointerType;
13941 typedef Type ValueType;
int32_t ErrorLimitTriggerSampleGet()
Get the controller sample at which the Position Error Limit condition most recently became true.
void FilterCoeffSet(RSIFilterGainPIDCoeff coeff, int32_t gainTable, double coeffValue)
Set a filter coefficient (ex: Kp, Ki, Kd).
void ErrorLimitDurationSet(double seconds)
Sets the duration required before the Position Error Limit event triggers.
double PositionErrorGet()
Get the current position error.
void HomeTravelDistanceSet(RSIHomeStage stage, double distanceToTravel)
Set the max travel used in a specific Homing Stage.
bool HomeLimitGet()
Get the current state of the Home limit.
RSIMotorFeedbackFault EncoderFaultTriggerGet()
Get the encoders which are used to generate encoder faults.
RSIAction AmpFaultActionGet()
Get the Amp Fault action.
int32_t FrameBufferSizeGet()
double SettlingTimeGet()
Get the Settling time.
int32_t SoftwareNegLimitTriggerSampleGet()
Get the controller sample at which the Software Negative Limit condition most recently became true.
Set the slow home velocity.
double CommandPositionGet()
double BrakeApplyDelayGet()
Get the delay time for the brake to be applied.
uint32_t DigitalOutputsGet()
Get all 32 digital output bits at once for this axis.
RSIMotorStepperPulseType StepperMotorPulseTypeGet(RSIMotorStepperPulse pulse)
Determine how the stepper pulse outputs are configured.
void MoveSCurve(double position)
MoveSCurve with the Axis defaults trajectory values from DefaultVelocitySet, DefaultAccelerationSet,...
bool DigitalIoExists(RSIMotorGeneralIo motorGeneralIoNumber)
Determine if a particular General I/O bit exists for a motor.
void SoftwarePosLimitTriggerValueSet(double triggerValue)
Set the Software Positive Position limit.
double AnalogInGet(int32_t channel)
RSIAxisMasterType GearingSourceGet()
Get the Source used to slave to the Master Axis.
void CommandPositionSet(double position)
Sets the value of the command and actual positions of an axis.
const char *const DigitalIoNameGet(RSIMotorGeneralIo motorGeneralIoNumber)
Get the name of a Motor I/O bit.
RSIAction HomeBehaviorGet()
Get the Action used during Master based Homing.
void FeedbackPointerSet(RSIAxisPositionInput input, uint64_t address)
Configure an axis for dual loop feedback.
RSIMotorType MotorTypeGet()
Get the motor type.
void AmpDisableActionSet(RSIMotorDisableAction action)
Set the Amp Disable action.
double SoftwareNegLimitTriggerValueGet()
Get the Software Negative Position limit.
Set the origin position.
double UserUnitsGet()
void BacklashRateSet(double rate)
Sets the rate at which Backlash is applied.
bool AmpEnableGet()
void SettleOnStopSet(bool state)
Set the Stop Event settling configuration.
int32_t DriveIndexGet()
Get the drive index, relative to the Network Node (multi-axis drives).
void HomeBehaviorSet(RSIAction behavior)
Set the Action used for Master based homing.
bool HomeSwitchGet()
void MoveRelative(double relativePosition)
int32_t AmpFaultTriggerSampleGet()
Get the controller sample at which the Amp Fault condition most recently became true.
double EncoderFaultDurationGet()
Get the duration required before the Encoder Fault Limit event triggers.
bool SettleOnEStopCmdEqActGet()
Get the E-Stop Event settling configuration when E-Stop is configured for (Command = Actual).
Execute the homing routine.
RSIMotorIoTypeMask DigitalIoValidTypesMaskGet(RSIMotorGeneralIo motorGeneralIoNumber)
Get the type mask for a Motor I/O bit.
int32_t FilterGainTableSizeGet()
Gets the size of gain tables.
Set the axis operation mode.
int32_t HardwarePosLimitTriggerSampleGet()
Get the controller sample at which the Hardware Positive Limit condition most recently became true.
void CommandPositionDirectSet(double position)
directly sets the value of the command position of an axis
RSIHomeMethod HomeMethodGet()
Get the method to be used for homing.
int32_t MotorFaultMaskGet()
Get the Motor Fault Mask.
void MoveCamLinear(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, const double *const masterDistances, const double *const slavePositions, int32_t pointCount)
void BrakeModeSet(RSIMotorBrakeMode mode)
Set the brake mode.
Set the home velocity.
bool DigitalInGet(RSIMotorGeneralIo motorGeneralIoNumber)
Read a digital input.
int32_t SoftwarePosLimitTriggerSampleGet()
Get the controller sample at which the Software Positive Limit condition most recently became true.
double CompensationPositionGet()
Get the compensator position.
double TriggeredModifyDecelerationGet()
Get the deceleration rate for an Triggered Modify Event.
void BacklashHysteresisLimitSet(double hysteresisLimit)
Brief.
void MoveVelocitySCurve(double velocity, double accel, double jerkPct)
Command a constant velocity move (jog) with non-constant acceleration.
void FilterAlgorithmSet(RSIFilterAlgorithm algorithm)
Set the algorithm type for an axis.
int32_t HomeLimitCustomConfigBitIndexGet()
sets the trigger state.
const char *const UserLabelGet()
Get the axis User defined Label.
void PostTrajectoryGearingMasterAxisSet(int32_t masterAxisNumber)
Set the master axis for post-trajectory gearing.
NetworkNode * NetworkNode
int32_t FilterGainTableGet()
Gets which gain table is currently in use by the axis.
double BacklashHysteresisLimitGet()
Get the backlash hysteresis limit.
double ActualVelocityGet()
Get the current actual velocity.
double HomeAccelerationGet(RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
Get the deceleration used for homing.
bool PositiveLimitGet()
void PostFilterHighPassSet(int32_t sectionNumber, double cornerFreq)
Use a High Pass Post Filter.
double OriginPositionGet()
Get the origin position.
void EStopJerkPercentSet(double jerkPct)
Set the jerk percent for an E-Stop, Modify Event.
Set the Amp Fault action.
void EncoderFaultActionSet(RSIAction action)
Set the action that will occur when the Encoder Fault Limit Event triggers.
int32_t GearingDenominatorGet()
Get the denominator of the gearing ratio.
void FilterGainTableSet(int32_t gainTable)
Set the gain table to be used by an axis.
void DigitalOutSet(RSIMotorGeneralIo motorGeneralIoNumber, bool outValue)
Set a digital output bit.
void MoveTrapezoidal(double position)
bool DedicatedOutExists(RSIMotorDedicatedOut motorDedicatedOutNumber)
Determine if a particular Dedicated output bit exists for a motor.
bool StepperMotorLoopbackGet()
Determine if the stepper is open or closed loop.
void BrakeApplyDelaySet(double seconds)
Set the brake apply delay.
void MotionCamRepeatFromSet(int32_t repeatFrom)
Set the segment at which camming repeats.
RSIAction HomeActionGet()
Get the action that will occur when the Home LIMIT triggers.
void PostFilterBiquadSet(int32_t sectionNumber, double aOne, double aTwo, double bZero, double bOne, double bTwo)
Use a Digital Biquad Post Filter.
void DigitalIoTypeSet(RSIMotorGeneralIo motorGeneralIoNumber, RSIMotorIoType type)
Set the type for a Motor I/O bit.
double HomeJerkPercentGet(RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
Get the Jerk Percent used for homing.
void HomeTriggerStateSet(bool state)
Set the trigger state for the Home input.
uint32_t DedicatedOutputsGet()
Get all 32 dedicated output bits at once for this axis.
RSIAction SyncGroupFaultActionGet()
Get the action taken when this Axis's node's EtherCAT sync group faults.
int32_t EncoderFaultTriggerSampleGet()
Get the controller sample at which the Encoder Fault condition most recently became true.
void EncoderRatioSet(RSIMotorFeedback encoder, int32_t numerator, int32_t denominator)
Sets the ratio to scale Encoder counts.
Change the electronic gearing ratio.
bool DigitalOutGet(RSIMotorGeneralIo motorGeneralIoNumber)
Get the state of digital output bit.
RSIHomeStage HomeStageGet()
Get the current Homing Stage.
static constexpr double AmpEnableAmpFaultTimeoutSecondsDefault
Default time an Axis waits before generating an AmpFault if the Axis does not enable after calling Am...
RSIMotorDisableAction AmpDisableActionGet()
Get the Amp Disable action.
void MoveSCurve(double position, double vel, double accel, double decel, double jerkPct, double finalVel)
double TargetPositionGet()
Get the target position.
double BacklashRateGet()
Gets the Backlash Rate which was set by the user.
double AmpFaultDurationGet()
double FilterCoeffGet(RSIFilterGainPIDCoeff coeff, int32_t gainTable)
Get value for a filter coefficient (ex: Kp, Ki, Kd, etc).
trigger state return.
bool SettleOnStopGet()
Get the Stop Event settling configuration.
double SoftwarePosLimitTriggerValueGet()
Get the Software Positive Position limit.
void EncoderFaultDurationSet(double seconds)
Set the duration required before the Encoder Fault Limit event triggers.
double ErrorLimitTriggerValueGet()
Get the Position Error Limit trigger value.
void PostFilterLowPassSet(int32_t sectionNumber, double frequency)
Use a Low-Pass filter.
RSIAction SoftwareNegLimitActionGet()
Get the action that will occur when the Software Negative Limit Event triggers.
void HomeCancelSet(bool cancel)
Cancel Homing.
void PostTrajectoryGearingMultiplierSet(double multiplier)
Set the multiplier for post-trajectory gearing.
void MoveRelative(double relativePosition, double vel, double accel, double decel, double jerkPct, double finalVel)
double EStopJerkPercentGet()
Get the jerk percent for an E-Stop, Modify Event.
int32_t PostTrajectoryGearingMasterAxisGet()
Get the master axis number used for post-trajectory gearing.
double CommandAccelGet()
Get the current commanded acceleration.
double HomeVelocityGet(RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
Get the home velocity.
void PostFilterSingleOrderSet(int32_t sectionNumber, double aOne, double bZero, double bOne)
Use a Single Order Post Filter.
void PostFilterLeadLagSet(int32_t sectionNumber, double lowGain, double highGain, double centerFreq)
Use a Lead Lag Post Filter.
void HomeStateSet(bool homed)
Set the home state.
bool DedicatedInExists(RSIMotorDedicatedIn motorDedicatedInNumber)
Determine if a particular Dedicated input bit exists for a motor.
void BacklashWidthSet(double width)
Sets the total range of the give in a system with Backlash.
double BacklashWidthGet()
Gets the Backlash Width which was set by the user.
RSIOperationMode OperationModeGet()
Get the operation mode.
void MotionCamMasterStartSet(Axis *master, double startPosition)
Set the position at which camming starts.
void FilterDualLoopSet(Axis *velocityAxis, RSIMotorFeedback velocityEncoder, bool enable)
void MoveTrapezoidal(double position, double vel, double accel, double decel, double finalVel)
bool SettleOnEStopGet()
Get the E-Stop Event settling configuration.
int32_t GearingNumeratorGet()
Get the numerator of the gearing ratio.
uint16_t MotionIdExecutingGet()
RSIAction EncoderFaultActionGet()
Get the action that will occur when the Encoder Fault Limit Event triggers.
void EncoderFaultTriggerSet(RSIMotorFeedbackFault encoder)
Set the encoders which are used to generate encoder faults.
RSIFilterAlgorithm FilterAlgorithmGet()
Get the control algorithm type for an axis.
double CommandVelocityGet()
Get the current commanded velocity.
int32_t FramesToExecuteGet()
bool HomeTriggerStateGet()
Get the trigger state for the Home input.
uint64_t GearingMasterAddressGet()
Get the address of the gearing master.
void StepperMotorPulseTypeSet(RSIMotorStepperPulse pulse, RSIMotorStepperPulseType type)
Set how the stepper pulse outputs are configured.
void EncoderCountSet(int32_t count)
void StepperMotorLoopbackSet(bool loopback)
Configure the stepper to be open or closed loop.
void CompensationPositionSet(double position)
Set the compensator position.
double BacklashValueGet()
Gets the current backlash compensation value.
double PostTrajectoryGearingScaledOffsetGet()
Get the current scaled position offset from post-trajectory gearing.
double HomeDecelerationGet(RSIHomeStage homeStage=RSIHomeStage::RSIHomeStageSTAGE_ONE)
Get the decleration to be used for homing when using the switch is not detected before the HomeTravel...
double EStopDecelerationGet()
int32_t HardwareNegLimitTriggerSampleGet()
Get the controller sample at which the Hardware Negative Limit condition most recently became true.
double EncoderPositionGet(RSIMotorFeedback encoder)
Get the raw encoder position.
void MotorFaultMaskSet(int32_t faultMask)
Set the Motor Fault Mask.
double VelocityToleranceGet()
void HomeDurationSet(double seconds)
Set the duration required before the Home event triggers.
double TriggeredModifyJerkPercentGet()
Get the jerk percent for an Triggered Modify Event.
void MoveCamCubic(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, const double *const masterDistances, const double *const slavePositions, const double *const gearRatios, int32_t pointCount)
Enable this Axis to be cubic follower (slave) using an electronic cam.
void PostFilterClear(int32_t sectionNumber)
Remove any Post Filters in section Number.
double HomeDurationGet()
Get the duration required before the Home event triggers.
bool NegativeLimitGet()
bool HomeStateGet()
Get the home state.
void SettleOnEStopSet(bool state)
Set the E-Stop Event settling configuration.
Set the motor type.
void SoftwareNegLimitTriggerValueSet(double triggerValue)
Set the Software Negative Position limit.
void GearingDisable()
Disable the electronic gearing.
void HomeLimitCustomConfigSet(uint64_t address, int32_t bitIndex)
double BrakeReleaseDelayGet()
Get the brake release delay time.
uint32_t DedicatedInputsGet()
Get all 32 dedicated input bits at once for this axis.
bool AmpFaultGet()
void NetworkIndexSet(RSINetworkIndexType indexType, uint32_t newIndex)
Override the PDO array index for an axis signal mapping.
int32_t GearingMasterAxisNumberGet()
Get a Slave's Master Axis Number.
void SyncGroupFaultActionSet(RSIAction action)
Set the action taken when this Axis's node's EtherCAT sync group faults.
bool DedicatedInGet(RSIMotorDedicatedIn motorDedicatedInNumber)
RSIMotorBrakeMode BrakeModeGet()
Get the brake mode.
Trigger state return.
void PostFilterNotchSet(int32_t sectionNumber, double centerFreq, double bandwidth)
Use a Notch Post Filter.
double ActualPositionGet()
uint16_t MotionElementIdExecutingGet()
void FrameBufferSizeSet(int32_t frameSize)
void FilterLowPassSet(double frequency)
double MotionCamMasterStartGet(Axis *master)
Gets the position on the master that will start the cam when exceeded.
RSIAction ErrorLimitActionGet()
Get the action that will occur when the Position Error Limit Event triggers.
void GearingEnable(int32_t masterAxisNumber, RSIAxisMasterType masterFeedbackSource, int32_t numerator, int32_t denominator)
double HomeSlowVelocityGet()
Get the slow home velocity.
void HomeJerkPercentSet(double percent)
Set the Jerk Percent used for homing.
RSIAction SoftwarePosLimitActionGet()
Get the action that will occur when the Software Positive Limit Event triggers.
void PostFilterUnityGainSet(int32_t sectionNumber)
Use a Unity Gain Post Filter.
double HomeOffsetGet()
Get the home offset.
void MotionCamRepeatStop()
Stops a Repeating Cam.
double ErrorLimitDurationGet()
Get the duration required before the Position Error Limit event triggers.
double PostTrajectoryGearingMultiplierGet()
Get the multiplier for post-trajectory gearing.
void PostTrajectoryGearingEnableSet(bool enable)
Enable or disable post-trajectory gearing for this axis.
void MoveVelocity(double velocity, double accel)
Command a constant velocity move (jog).
void ActualPositionSet(double position)
Set the actual position.
void PostFilterResonatorSet(int32_t sectionNumber, double centerFreq, double bandwidth, double gain)
Use a Resonator Post Filter.
bool DedicatedOutGet(RSIMotorDedicatedOut motorDedicatedOutNumber)
Get the state of dedicated output bit.
bool PostTrajectoryGearingEnableGet()
Get the enable state of post-trajectory gearing.
double FilterLowPassGet()
Get the value of the Low-Pass filter.
void SettleOnEStopCmdEqActSet(bool state)
Set the settling configuration for E-Stop events (when configured for Command = Actual).
void BrakeReleaseDelaySet(double seconds)
Set the Brake Release Delay.
Sets the trigger state.
uint32_t DigitalInputsGet()
Get all 32 digital input bits at once for this axis.
bool GearingEnableGet()
Get the state of the gearing feature. If true, this Axis is a geared slave.
int32_t MotionCamRepeatFromGet()
Get the segment at which camming repeats.
Set the settling time.
void DefaultVelocitySet(double velocity)
Set the default velocity in UserUnits.
void EncoderRatioPrimarySet(char *numeratorCommaDenominator)
Set the primary feedback encoder ratio as text. "1.0 ,2.0".
bool LimitTriggerStateGet(RSIEventType limit)
Get the trigger state for any type of limit.
void NodeFailureActionSet(RSIAction action)
Set the action for a node failure.
double DefaultDecelerationGet()
Get the default deceleration in UserUnits.
uint64_t HomeLimitCustomConfigAddressGet()
Get the host address of the custom home input configuration.
static constexpr uint32_t NetworkIndexInvalid
Returned by NetworkIndexGet() when the index is invalid or nonexistent for this Axis.
void EncoderRatioSecondarySet(char *numeratorCommaDenominator)
Set the secondary feedback encoder ratio as text. "1.0 ,2.0".
double CommandJerkGet()
Get the current commanded jerk value (custom firmware required).
double FilterOutputGet(void)
Get the output of a demand filter, range is +/- 100.0.
void EncoderPointerSet(RSIMotorFeedback encoder, uint64_t address)
Set the pointer (host address) for the motor feedback.
bool IsTuneable()
Is an Axis tunable? Returns false if Axis is in position mode, otherwise true.
double DefaultPosition2Get()
Get the default Position 2 value in UserUnits (used by RapidSetup).
void LimitTriggerStateSet(RSIEventType limit, bool triggerState)
Set the trigger state for any type of limit.
double DefaultJerkPercentGet()
Get the default jerk percent.
double DefaultAccelerationGet()
Get the default acceleration in UserUnits.
const char *const EncoderRatioSecondaryGet()
Get the secondary feedback encoder ratio as text.
double DefaultVelocityGet()
Get the default velocity in UserUnits.
void FilterGainSchedulingSet(bool enable)
Enable or disable automatic gain scheduling.
double UserUnitsToCounts(double userUnits)
Convert from UserUnits to raw feedback counts.
const char *const PostFilterInfoGet()
Get a text description of the current post filters.
void GantryTypeSet(RSIAxisGantryType type)
Set the gantry type.
uint16_t StatusWordGet()
Get the DS402 status word.
double LimitTriggerValueGet(RSIEventType limit)
Get the trigger value for any type of limit.
double DefaultPosition1Get()
Get the default Position 1 value in UserUnits (used by RapidSetup).
int32_t ClosedLoopStepperVersionGet()
Unsupported.
uint64_t EncoderPointerGet(RSIMotorFeedback encoder)
Get the pointer (host address) for the motor feedback.
const char *const EncoderRatioPrimaryGet()
Get the primary feedback encoder ratio as text.
double LimitDurationGet(RSIEventType limit)
Get the duration for any type of limit.
void MotionFinalVelocitySet(double finalVelocity)
Set the final velocity of a motion, when FINAL_VEL motion attribute is used.
uint64_t FeedbackDeltaPointerGet(RSIAxisPositionInput input)
Get the pointer (host address) for the axis feedback.
bool FaultMaskBitGet(RSIMotorFaultMask bitMask)
Unsupported Function. Likely to be removed in the future.
void HomeLimitCustomConfigReset()
Remove any custom home input configuration and reset to use the Axis' dedicated home input bit.
void DefaultPosition1Set(double position1)
Set the default Position 1 value in UserUnits (used by RapidSetup).
double DefaultRelativeIncrementGet()
Get the default relative increment value in UserUnits (used by RapidSetup).
int32_t EncoderRatioDenominatorGet(RSIMotorFeedback encoder)
Get the encoder ration denominator.
void DefaultRelativeIncrementSet(double relativeIncrement)
Set the default relative value in UserUnits (used by RapidSetup).
double CountsToUserUnits(double counts)
Convert from raw feedback counts to UserUnits.
void DefaultPosition2Set(double position2)
Set the default Position 2 value in UserUnits (used by RapidSetup).
int32_t EncoderRatioNumeratorGet(RSIMotorFeedback encoder)
Get the encoder ratio numerator.
void ClosedLoopStepperSet(bool enable)
Unsupported.
RSIAction LimitActionGet(RSIEventType limit)
Get the action for any type of limit.
void LimitDurationSet(RSIEventType limit, double seconds)
Set the duration for any type of limit.
void FeedbackDeltaPointerSet(RSIAxisPositionInput input, uint64_t address)
Set the pointer (host address) for the axis feedback.
double MotionFinalVelocityGet()
Get final velocity of a motion, when FINAL_VEL motion attribute is used.
RSIAxisGantryType GantryTypeGet()
Get the gantry type.
uint64_t FeedbackPointerGet(RSIAxisPositionInput input)
void LimitActionSet(RSIEventType limit, RSIAction action)
Set the action for any type of limit.
RSIAction NodeFailureActionGet()
Get the action for a node failure.
void DefaultJerkPercentSet(double jerkPercent)
Set the default jerk percent.
void LimitTriggerValueSet(RSIEventType limit, double triggerValue)
Set the trigger value for any type of limit.
int32_t EncoderCountGet()
Get the number of encoders processed in firmware by the motor object. Valid values: 0,...
bool FilterGainSchedulingGet()
Get the status of automatic gain scheduling.
bool IOExists()
IOExists validates your IO object is an IO Node.
bool DigitalInGet(int32_t digitalInNumber)
Get the state of a digital input bit.
Get the IO User defined Label.
Set the IO User defined Label.
int32_t AnalogInGet(int32_t analogChannel)
bool DigitalOutGet(int32_t digitalOutNumber)
Get the state of a Digital Output bit.
int32_t NumberGet()
Get the zero-based IO number.
int32_t AnalogOutGet(int32_t analogChannel)
Get the value of an analog output.
void DigitalOutSet(int32_t digitalOutNumber, bool outValue)
Set the state of a digital output bit.
Set the value of an analog output.
Gets the parent NetworkNode object.
MotionController * rsiControl
static IOPoint * CreateDigitalInput(Axis *axis, RSIMotorGeneralIo motorGeneralIoNumber)
Create a Digital Input from an Axis' general purpose inputs.
void ValueSet(double valueDouble)
Set the value for an Analog Output.
double ValueGet()
Get the value of an Analog Input or Output.
bool IsOutput()
Determine if an I/O point is an output.
static IOPoint * CreateDigitalInput(NetworkNode *networkNode, int32_t bitNumber)
Create a Digital Input from a RapidCodeNetworkNode.
static IOPoint * CreateDigitalOutput(MotionController *controller, uint64_t memoryAddress, int32_t bitNumber)
Create a Digital Output from a network PDO.
void Set(bool state)
static IOPoint * CreateDigitalOutput(Axis *axis, RSIMotorGeneralIo motorGeneralIoNumber)
Create a Digital Output from an Axis' general purpose inputs.
static IOPoint * CreateAnalogInput(NetworkNode *networkNode, int32_t analogChannel)
Create an Analog Input from a RapidCodeNetworkNode.
static IOPoint * CreateAnalogOutput(NetworkNode *networkNode, int32_t analogChannel)
Create an Analog Output from a RapidCodeNetworkNode.
static IOPoint * CreateDigitalOutput(MotionController *controller, int32_t pdoIndex, int32_t bitNumber, RSIPDOType type)
bool IsDigital()
Determine if an I/O point is Digital or Analog.
static IOPoint * CreateDigitalInput(MotionController *controller, uint64_t memoryAddress, int32_t bitNumber)
static IOPoint * CreateDigitalInput(MotionController *controller, int32_t pdoIndex, int32_t bitNumber, RSIPDOType type)
static IOPoint * CreateDigitalOutput(NetworkNode *networkNode, int32_t bitNumber)
Create a Digital Output from a RapidCodeNetworkNode.
bool Get()
NetworkNode * NetworkNodeGet(int32_t nodeNumber)
NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializ...
void InterruptWake()
Wake all threads waiting for a controller interrupt.
static MotionController * Get(const char *const nodeName)
[Windows] Get an already running RMP EtherCAT controller by its INtime node name.
int32_t NetworkSyncGroupCountGet()
Get the number of sync groups present on the network.
void UserLimitReset(int32_t number)
Clear the latched status of a User Limit.
int32_t UserLimitCountGet()
Get the number of UserLimits processing in the firmware.
uint64_t NetworkOutputValueGet(int32_t index)
Gets the value sent out over EtherCAT.
void RecorderStart()
Start recording data.
int32_t RecorderBufferSizeGet(int32_t recorderNumber)
Get Frame buffer size for the Recorder.
void UserVersionSet(int32_t version)
Sets a customer designed Version for the application.
Sets a PDO output directly.
void RecorderBufferSizeSet(int32_t recorderNumber, int32_t bufferSize)
Set buffer size for the Recorder.
bool RecorderTriggerOnMotionGet(int32_t recorderNumber)
Check to see if the Recorder is set to trigger on motion.
FirmwareValue NetworkOutputIntendedFirmwareValueGet(int32_t index)
Gets the typed value set by the cyclic RMP processes.
RSINetworkEniResult NetworkEniGenerate()
Generate the network ENI file, EtherCAT.xml.
void SampleRateSet(double sampleRate)
Configure the RMP firmware control loop frequency.
const char *const FirmwareVersionGet()
Get the firmware version.
void Reset()
Reset the controller which stops and restarts the RMP firmware.
uint64_t FirmwareAddressGet(uint64_t hostAddress)
Convert a host controller address to a firmware address.
int32_t NetworkInputBitOffsetGet(int32_t index)
void RecorderConfigureToTriggerOnMotion(Axis *axis, bool triggerOnMotion)
Configure the Recorder 0 to trigger on Axis motion.
void SyncInterruptHostProcessStatusClear()
Clear the Host Process status bit.
uint64_t NetworkOutputOverrideValueGet(int32_t index)
int32_t CompensatorCountGet()
Get the number of Compensators available in the firmware.
int32_t ExternalMemorySizeGet()
const char *const NetworkOutputDataTypeNameGet(int32_t index)
Get the data type name (as a string) of a PDO network output.
const int32_t *const RecorderRecordDataGet()
Get one record of recorded data on Recorder 0.
void ServiceThreadEnableSet(bool enable)
Enable or disable the service thread.
RSIDataType AddressDataTypeGet(RSIControllerAddressType type)
Get the data type for an address on the MotionController.
RSIDataType NetworkInputDataTypeGet(int32_t index)
Get the RSIDataType for a PDO input.
void UserLimitOutputSet(int32_t number, uint32_t andMask, uint32_t orMask, uint64_t outputPtr, bool enabled)
Configure a User Limit Output block.
int32_t RecorderRecordMaxCountGet()
Get the maximum number of records the recorder can store on Recorder 0.
int32_t CompensatorPointCountGet(int32_t compensatorNumber)
Get the number of points for use with a Compensator.
int32_t NetworkNodeCountGet()
Get the number of nodes discovered on the EtherCAT network.
void CompensatorEnable(int32_t compensatorNumber)
Enables the compensator only if it will cause no errors.
void NetworkSyncGroupRecover(int32_t groupId, uint32_t timeoutMilliseconds=NetworkSyncGroupRecoverTimeoutMillisecondsDefault)
Recover a degraded (non-zero) sync group back to Operational without restarting the network.
bool UserLimitEnableGet(int32_t number)
Get the enabled state of a User Limit.
FirmwareValue NetworkOutputSentFirmwareValueGet(int32_t index)
Gets the typed value sent out over EtherCAT.
void CompensatorPointCountSet(int32_t compensatorNumber, int32_t pointCount)
Set the number of points for use with a Compensator.
NetworkSyncGroupStatus NetworkSyncGroupStatusGet(int32_t groupId)
Get the status of a single sync group.
RSIProcessorType ProcessorTypeGet()
Get the processor type.
uint64_t AddressFromStringGet(const char *const addressName)
Get a controller memory address from string.
void CompensatorTableGet(int32_t compensatorNumber, double *table)
Read the table for a configured compensator.
bool IsLicensed()
Check to see if this MotionController is licensed.
uint64_t NetworkOutputIntendedValueGet(int32_t index)
Gets the value set by the cyclic RMP processes.
uint64_t NetworkOutputSentValueGet(int32_t index)
static MotionController * CreateFromFile(const char *const fileName)
Create a MotionController from a memory-dumped file.
void RecorderDataAddressesSet(int32_t recorderNumber, const uint64_t *const addresses, int32_t addressCount)
Setup multiple addresses to record at once.
void SyncInterruptHostProcessFlagSet(bool hostProcessFlag)
Set the Host Process flag.
double CompensatorPositionGet(int32_t compensatorNumber)
void NetworkShutdown()
Shutdown the EtherCAT network.
int32_t MemoryGet(uint64_t address)
Read controller memory.
uint64_t NetworkOutputAddressGet(int32_t index)
Get the host address for a Network Output.
void MemoryToFile(const char *const fileName)
Saves an RMP firmware memory dump which can be compared with others.
int32_t BackgroundCycleCounterGet()
Get the current value of the controller's processor's background cycle counter.
void NetworkStart()
Start the network, doing both a discovery followed by starting to OPERATIONAL state.
void MotionHoldGateSet(int32_t gateNumber, bool hold)
Set the Motion Hold Gate.
Configure a User Limit.
const char *const NetworkEniGenerateOutputGet()
Retrieve the text output from the previous NetworkEniGenerate() call.
void CompensatorTableSet(int32_t compensatorNumber, const double *const table)
Override the table for a configured compensator.
static constexpr double SampleRateDefault
Default RMP sample rate in hertz.
void MemoryBlockSet(uint64_t address, const void *const dataStart, int32_t size)
Set controller memory.
uint64_t HostAddressGet(uint64_t firmwareAddress)
Convert a firmware address to a host controller address.
uint64_t NetworkInputAddressGet(int32_t index)
Get the host address for a PDO input.
void RecorderStop()
const char *const NetworkLogMessageGet(int32_t messageIndex)
static MotionController * CreateFromSoftware(const char *const RtaPath, const char *const NodeName)
int32_t MathBlockCountGet()
int32_t SyncInterruptHostProcessTimeGet()
Get the total number of microseconds availble for host processing.
int32_t FirmwareOptionGet()
Get the firmware option number.
int32_t SampleCounterGet()
Get the current value of the controller's processor's sample counter.
void NetworkOutputOverrideFirmwareValueSet(int32_t index, FirmwareValue value)
Sets a typed PDO override value.
double ProcessorUsageGet()
Get the processor usage percent.
int32_t AxisFrameBufferSizeGet(int32_t axisNumber)
Get Frame buffer size for the axis.
int32_t UserVersionGet()
Get a customer designated Version for the application.
void CompensatorDisable(int32_t compensatorNumber, bool force=false)
Disable a compensator with the option to force the action.
static MotionController * CreateFromSoftware(const char *const RtaPath)
bool SyncInterruptHostProcessStatusBitGet()
See if the host was processing too int32_t on previous Sync Interrupt.
void RecorderReset()
uint32_t FirmwareTimingDeltaGet()
Get the most recent time (in microseconds) between samples.
int32_t RecorderCountGet()
Get the number of Recorder available in the firmware.
FirmwareValue NetworkInputFirmwareValueGet(int32_t index)
Get the typed value for a PDO input.
FirmwareValue NetworkOutputOverrideFirmwareValueGet(int32_t index)
Gets the typed PDO override value.
CreationParameters CreationParametersGet()
Get the CreationParameters identifying this controller's firmware.
RSIDataType NetworkOutputDataTypeGet(int32_t index)
Get the RSIDataType for a PDO output.
void AxisFrameBufferSizeSet(int32_t axisNumber, int32_t frameBufferSize)
Set Frame buffer size for the axis.
int32_t UserLimitCountMax()
Get the total number of User Limits available.
void Refresh()
Refresh / reinitialize the motion controller. Required after changing dynamic memory object counts.
void Shutdown()
Shutdown the controller.
bool UserLimitStateGet(int32_t number)
Get the state of a User Limit.
int32_t CompensatorDimensionGet(int32_t compensatorNumber)
Get the dimension of the compensator.
void MemoryBlockGet(uint64_t address, void *dataStart, int32_t size)
int32_t AxisCountGet()
int32_t MotionCountGet()
NetworkStatus NetworkStatusGet()
Get the EtherCAT network status.
MultiAxis * LoadExistingMultiAxis(int32_t motionSupervisorNumber)
Get/Create a MultiAxis object from one that already exists (previously setup) on the RMP motion contr...
double MemoryDoubleGet(uint64_t address)
Read a 64-bit double value from controller memory.
void CompensatorCountSet(int32_t compensatorCount)
Set the number of Compensators available in the firmware.
int32_t NetworkLogMessageCountGet()
bool MotionHoldGateGet(int32_t gateNumber)
bool RecorderEnabledGet()
int32_t SyncInterruptWait()
bool NetworkOutputOverrideGet(int32_t index)
Gets if the NetworkOutputValue or the RMP cyclic value is exchanged over EtherCAT.
void ProcessorUsageClear()
Clear the processor usage percent.
int32_t RecorderRecordDataRetrieveBulk(int32_t recorderNumber, int32_t recordCount)
Retrieve a group of records of recorded data.
void CompensatorConfigSet(int32_t compensatorNumber, int32_t firstInputAxisNumber, RSIAxisMasterType firstInputAxisType, double firstInputAxisMinimum, double firstInputAxisMaximum, double firstInputAxisDelta, int32_t secondInputAxisNumber, RSIAxisMasterType secondInputAxisType, double secondInputAxisMinimum, double secondInputAxisMaximum, double secondInputAxisDelta, int32_t outputAxisNumber, RSICompensatorOutputType outputType, const double *const table)
Configure a 2D compensator.
void RecorderBufferHighCountSet(int32_t bufferHighCount)
Set the high count for the recording buffer on Recorder 0.
void CompensatorTableClear(int32_t compensatorNumber)
Sets all values in the compensator table to 0.
uint32_t SerialNumberGet(void)
const char *const StringFromAddressGet(uint64_t hostAddress)
Get a human-readable string from a memory address.
int32_t NetworkOutputCountGet()
const char *const NetworkInputDataTypeNameGet(int32_t index)
Get the data type name (as a string) of a PDO network input.
int32_t UnsupportedOptionSet(int32_t option)
deprecated
RSIControllerType ControllerTypeGet()
Get the type of motion controller.
int32_t UserLimitOutputValueGet(int32_t number)
Get the user limit output value.
uint32_t NetworkTimingThresholdHighCountGet()
Get the number of network packets that were sent to slowly (above the high threshold).
bool HasMechaWare()
Returns true if this RMP firmware supports MechaWare.
uint64_t UserLimitOutputAddressGet(int32_t number)
Get the user limit output address. The output will write its value to this address.
uint32_t UserLimitConditionMaskGet(int32_t number, int32_t conditionNumber)
Get the user limit condition mask.
int32_t SyncInterruptHostProcessFlagGet()
Get the host process flag.
bool NetworkSynchronizedGet()
Returns true if the network is synchronized with distributed clocks.
static constexpr uint32_t MotionControllerCountMaximum
Maximum number of MotionController objects supported in a single process.
uint32_t NetworkTimingMinGet()
Get the minimum microseconds recorded between network packets.
uint64_t UserLimitConditionAddressGet(int32_t number, int32_t conditionNumber)
Get the user limit condition address.
Get the name of a PDO output.
int32_t ServerPortGet()
Get the TCP port of the server. (Valid if controller type is CLIENT.).
uint32_t NetworkTimingThresholdLowCountGet()
Get the number of network packets that were sent to quickly (below the low threshold).
uint32_t NetworkTimingMaxGet()
Get the maximum microseconds recorded between consecutive network packets.
uint64_t UserLimitOutputAndMask64Get(int32_t number)
Get the user limit output 64-bit AND mask.
RSIAction UserLimitActionGet(int32_t number)
Get the user limit action.
static constexpr uint32_t NetworkSyncGroupRecoverTimeoutMillisecondsDefault
Default per-node AL-transition time to wait when calling NetworkSyncGroupRecover().
uint32_t UserLimitOutputOrMaskGet(int32_t number)
Get the user limit output OR mask.
int32_t NetworkOutputBitOffsetGet(int32_t index)
Get the raw PDO offset for an output.
int32_t AxisLicenseCountGet()
Get the number of licensed Axis objects on this motion controller. If you need more,...
RapidCodeOS * OS
bool ServiceThreadStateGet()
Returns true if the service thread was started.
static constexpr uint32_t RecorderCountMaximum
Maximum number of Recorder objects supported.
uint32_t UserLimitOutputAndMaskGet(int32_t number)
Get the user limit output AND mask.
bool UserLimitSingleShotGet(int32_t number)
Returns true if the user limit is configured for single-shot.
bool UserLimitOutputEnableGet(int32_t number)
Returns true if the user limit output is enabled.
const char *const ServerNameGet()
Get the name of the server. (Valid if controller type is CLIENT.).
bool MechaWareLicenseGet()
Returns true if this motion controller is licensed to run MechaWare.
int32_t PackageVariantGet()
Get the motion controller package.
RSIUserLimitLogic UserLimitConditionLogicGet(int32_t number, int32_t conditionNumber)
Get the user limit condition logic.
static constexpr uint32_t AxisCountMaximum
Maximum number of Axis objects supported.
void UserLimitEnableSet(int32_t number, bool enable)
Enable or disable a user limit to be processed by the RMP firmware.
double UserLimitOutputDoubleGet(int32_t number)
Get the user limit output 64-bit double value.
static constexpr uint32_t NetworkStartTimeoutMillisecondsDefault
Default time to wait when calling NetworkStart().
void NetworkTimingEnableSet(bool enable)
Enable or disable the firmware to start timing the network packets.
RSINetworkStartError LastNetworkStartErrorGet()
Get the last (most recent) network start error.
void NetworkTimingThresholdHighSet(uint32_t microseconds)
Set a high threshold. The RMP will count the number of network packets sent above this threshold (too...
uint64_t UserLimitInterruptUserDataAddressGet(int32_t number, uint32_t userDataIndex)
Get the user limit interrupt user data address.
static constexpr uint32_t CompensatorCountMaximum
Maximum number of position Compensator objects supported.
RSINetworkType NetworkTypeGet()
Returns network type. (Currently only STRING type is supported.).
int32_t NetworkCounterGet()
Read the network counter. This increments by one for each cycle of the network.
uint64_t UserLimitOutputInputAddressGet(int32_t number)
Get the user limit output address. The user limit will output the value stored at this address when t...
RSINetworkTechnologyType NetworkTechnologyTypeGet()
Get the network technology type EtherCAT.
static constexpr uint32_t UserBufferDataCountMaximum
Maximum number of 64-bit values that can be stored in the UserBuffer.
uint32_t NetworkTimingDeltaGet()
Get the number of microseconds since the previous network packet was sent.
RSIDataType UserLimitConditionDataTypeGet(int32_t number, int32_t conditionNumber)
Get the user limit condition data type.
double UserLimitConditionLimitValueDoubleGet(int32_t number, int32_t conditionNumber)
Get the user limit condition limit value (as 64-bit double).
static constexpr uint32_t NetworkSyncGroupCountMaximum
Maximum number of EtherCAT sync groups supported, including the mandatory default group 0....
int32_t UserLimitConditionLimitValueGet(int32_t number, int32_t conditionNumber)
Get the user limit condition value.
RSIDataType UserLimitOutputDataTypeGet(int32_t number)
Get the user limit output data type.
int32_t UserLimitAxisNumberGet(int32_t number)
Get the user limit axis number.
static constexpr uint32_t MathBlockCountMaximum
Maximum number of MathBlock objects supported.
double UserLimitDurationGet(int32_t number)
Get the user limit duration (seconds).
static constexpr uint32_t NetworkNodeCountMaximum
Maximum number of nodes allowed on the network.
static constexpr uint32_t MotionCountMaximum
Maximum number of Motion objects supported. (One required for each Axis and MultiAxis).
bool NetworkTimingEnableGet()
Returns true if firmware network packet timing metrics are enabled.
void NetworkTimingThresholdLowSet(uint32_t microseconds)
Set a low threshold. The RMP will count the number of network packets sent below this threshold (too ...
FirmwareValue RecorderRecordDataFirmwareValueGet(int32_t index)
RSIUserLimitTriggerType UserLimitTriggerTypeGet(int32_t number)
Get the user limit trigger type.
uint64_t UserLimitOutputOrMask64Get(int32_t number)
Get the user limit output 64-bit OR mask.
void NetworkTimingClear()
Clear all the network timing values.
void MoveVelocitySCurve(const double *const velocity, const double *const accel, const double *const jerkPct)
Velocity move with non-constant acceleration.
void PathListStart(const double *const startPosition)
Start a line and arc point list for path motion.
void PathMotionStart()
Start the path motion.
void PathArcAdd(const double *const center, double angle)
Add an arc segment to the path.
Axis * AxisGet(int32_t index)
Get the Axis class used in this MultiAxis class.
bool AmpEnableGet()
Get the enabled/disabled state of the multi axis.
void PathRatioSet(const double *const ratio)
Set the scale factor ratios for each axis.
double VectorJerkPercentGet()
Get the vector jerk percent.
uint64_t AddressGet(RSIMultiAxisAddressType addressType)
Get the host address for some location on the MultiAxis.
double VectorAccelerationGet()
Get the vector acceleration.
RSIPathPlanType PathPlanTypeGet()
Get the path motion planning type.
Get the MultiAxis User defined Label.
Set the MultiAxis User defined Label.
double VectorVelocityGet()
Get the vector velocity.
double VectorDecelerationGet()
Get the vector deceleration.
void AxisRemoveAll()
RSIDataType AddressDataTypeGet(RSIMultiAxisAddressType type)
Get the data type for an address of the MultiAxis.
void MoveRelative(const double *const relativePosition, const double *const vel, const double *const accel, const double *const decel, const double *const jerkPct)
void VectorDecelerationSet(double deceleration)
Set the vector deceleration.
void MoveVector(const double *const position)
Point-to-point vector move.
void PathPlanTypeSet(RSIPathPlanType type)
Set the path motion planning type.
void MoveVectorRelative(const double *const relativePosition)
Point-to-point S-Curve Move.
void PathLineAdd(const double *const position)
Add a line segment to the path.
void PathTimeSliceSet(double seconds)
Set the time slice for the Path.
void PathBlendSet(bool blend)
Set the blending attribute.
void VectorAccelerationSet(double acceleration)
Set the vector acceleration.
Velocity move.
void VectorJerkPercentSet(double jerkPercent)
Set the jerk percent for a vector move.
double PathRatioGet(int32_t index)
void PathListEnd()
End a line and arc point list for path motion.
void AxisAdd(Axis *axis)
double PathTimeSliceGet()
void VectorVelocitySet(double velocity)
Set the vector velocity.
int32_t AxisMapCountGet()
Get the number of Axis objects in the Axis map.
Status StatusGet()
Get the node's status details.
void DigitalOutSet(int32_t digitalOutNumber, bool state)
Set the state of a digital output.
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Write a number in the SDO.
const char *const DigitalOutUserLabelGet(int32_t digitalOutNumber)
Get the user defined label of one of this node's digital outputs.
Get the state of a digital input.
static constexpr int32_t IoUserLabelBufferBytes
void AnalogOutUserLabelSet(int32_t analogChannel, const char *const userLabel)
Set the user defined label of one of this node's analog outputs.
uint64_t DigitalOutAddressGet(int32_t bitNumber)
Get the host address for a Node's digital output.
const char *const ServiceChannelReadString(int32_t index, int32_t subIndex, int32_t byteCount, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Read a string from the SDO.
RapidVector< uint8_t > ServiceChannelReadBytes(int32_t index, int32_t subIndex, int32_t byteCount, uint32_t timeoutMilliseconds)
Read a number of bytes from the SDO.
uint64_t AnalogInAddressGet(int32_t channel)
Get the host address for a Node's analog input.
int32_t DigitalInCountGet()
Get the number of digital inputs on this node.
const char *const AnalogInUserLabelGet(int32_t analogChannel)
Get the user defined label of one of this node's analog inputs.
Get this node's user defined label.
bool HasIO()
Check if the node has any analog or digital inputs or outputs.
Set this node's user defined label.
RSIDataType AddressDataTypeGet(RSINetworkNodeAddressType addressType)
Get the data type for one of this node's status addresses.
const char *const VendorNameGet()
Get the node's vendor name from NodeInfo.xml or CustomNodeInfo.xml.
int32_t AnalogInMaskGet(int32_t channel)
Get the bitwise mask for a Node's analog input.
void ConfigSet(const Config &config)
Set the node's configuration.
int32_t AnalogOutNetworkIndexGet(int32_t analogChannel)
Get the global network output index for a node's analog output channel.
const char *const DigitalInUserLabelGet(int32_t digitalInNumber)
Get the user defined label of one of this node's digital inputs.
int32_t DigitalOutNetworkIndexGet(int32_t digitalOutNumber)
Get the global network output index for a node's digital output channel.
uint64_t AddressGet(RSINetworkNodeAddressType addressType)
Get the host address for one of this node's status values.
int32_t DigitalOutMaskGet(int32_t bitNumber)
Get the bitwise mask for a Node's digital output.
int32_t ServiceChannelRead(int32_t index, int32_t subIndex, int32_t byteCount, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Get the state of a digital output.
Send an ASCII command to a supported Kollmorgen drive.
const char *const AnalogOutUserLabelGet(int32_t analogChannel)
Get the user defined label of one of this node's analog outputs.
const char *const NameGet()
Get the Node's Short Name that appears on NodeInfo.xml.
void DigitalInUserLabelSet(int32_t digitalInNumber, const char *const userLabel)
Set the user defined label of one of this node's digital inputs.
static constexpr int32_t UserLabelCharacterCountMaximum
void DigitalOutUserLabelSet(int32_t digitalOutNumber, const char *const userLabel)
Set the user defined label of one of this node's digital outputs.
uint64_t IoUserLabelGenerationGet()
Get the change counter that says whether any I/O point user label on this controller changed.
const char *const ProductNameGet()
Get the node's product name from NodeInfo.xml or CustomNodeInfo.xml.
int32_t AnalogInCountGet()
Get the number of analog inputs on this node.
int32_t DigitalOutCountGet()
Get the number of digital outputs on this node.
int32_t DigitalInNetworkIndexGet(int32_t digitalInNumber)
Get the global network input index for a node's digital input channel.
bool IsAKDASCIICommandSupported()
Check whether this node accepts Kollmorgen ASCII commands through AKDASCIICommand().
Config ConfigGet()
Get the node's configuration.
int32_t AnalogInNetworkIndexGet(int32_t analogChannel)
Get the global network input index for a node's analog input channel.
int32_t AnalogOutCountGet()
Get the number of analog outputs on this node.
void StatusClear()
Clear the node's status values.
void AnalogInUserLabelSet(int32_t analogChannel, const char *const userLabel)
Set the user defined label of one of this node's analog inputs.
void AnalogOutSet(int32_t analogChannel, int32_t analogValue)
uint64_t AnalogOutAddressGet(int32_t channel)
Get the host address for a Node's analog output.
int32_t AnalogOutMaskGet(int32_t channel)
Get the bitwise mask for a Node's analog output.
uint32_t RevisionGet()
Get the EtherCAT hardware revision.
uint32_t AxisCountGet()
Get the number of Axis objects associated with this NetworkNode.
int32_t SegmentDigitalOutCountGet(int32_t segmentNumber)
Get the number of digital outputs on a segment.
int32_t SegmentIDGet(int32_t segmentNumber)
Get the ID number of a segment.
uint32_t ProductCodeGet()
Get the EtherCAT product code.
int32_t SegmentCountGet()
Get the number of segments on this node.
int32_t SegmentAnalogOutCountGet(int32_t segmentNumber)
Get the number of analog outputs on a segment.
bool IsEtherCAT()
Check if the node is EtherCAT.
int32_t SegmentAnalogInCountGet(int32_t segmentNumber)
Get the number of analog inputs on a segment.
static constexpr uint32_t SDOTimeoutMillisecondsDefault
Default time to wait when reading or writing an SDO with ServiceChannelRead() or ServiceChannelWrite(...
uint32_t VendorIdGet()
Get the EtherCAT vendor ID.
bool IsSynqNet()
Check if the node is SynqNet.
void ClearFaults(int32_t axisNumber)
Clear the faults for a specific axis number on this node.
bool Exists()
Returns true if this NetworkNode exists on a physical network.
int32_t SegmentDigitalInCountGet(int32_t segmentNumber)
Get the number of digital inputs on a segment.
RSINodeType TypeGet()
Get the node type, as determined by the Vendor ID and Product Code.
uint32_t StationAliasGet()
Get the EtherCAT station alias.
const char *const SerialNumberGet()
Get the serial number as text.
static const char *const INtimeCatalogRMPNetworkGet()
Get the RMPNetwork catalog.
static INtimeStatus INtimeStatusGet(const char *const nodeName)
Get the status of INtime.
static INtimeStatus INtimeStart()
Start INtime.
static INtimeStatus INtimeRestart(const char *const nodeName)
Restart INtime (reboot INtime).
static uint32_t INtimeNodeCountGet()
Get the number of INtime nodes on this PC.
static const char *const INtimeCatalogRMPGet()
Get the RMP catalog.
static INtimeStatus INtimeStart(const char *const nodeName)
Start INtime.
static INtimeStatus INtimeStatusGet()
static bool INtimeNodeIsLocal(uint32_t nodeNumber)
Determine if an INtime node is local (on this PC) or distributed (on another PC).
static INtimeStatus INtimeStop(const char *const nodeName)
Stop INtime.
static const char *const INtimeNodeNameGet(uint32_t nodeNumber)
Get the name of an INtime node.
static INtimeStatus INtimeRestart()
static INtimeStatus INtimeStop()
Stop INtime.
Represents the real-time operating system (INtime) when using RMP for Windows. This class provides st...
double InterruptUserDataDoubleGet(uint32_t userDataIndex)
uint64_t InterruptUserDataAddressGet(uint32_t userDataIndex)
int32_t InterruptSampleTimeGet()
const char *const InterruptNameGet()
FirmwareValue InterruptUserDataValueGet(uint32_t userDataIndex)
void InterruptUserDataAddressSet(uint32_t userDataIndex, uint64_t hostAddress)
uint64_t InterruptUserDataGet(uint32_t userDataIndex)
Interface for objects which can use interrupts.
Wake any and all threads waiting for interrupts.
void InterruptMaskClear()
uint16_t InterruptMotionIdGet()
void InterruptMaskOnSet(RSIEventType eventType)
void InterruptMaskOffSet(RSIEventType eventType)
void InterruptMaskAllSet()
bool InterruptMaskOnGet(RSIEventType eventType)
Enable or disable interrupts.
Sets the Axis position.
Wake all threads waiting for an interrupt on this Axis.
bool MotionHoldGateGet()
double MotionHoldAxisPositionGet()
Gets the Axis position.
double MotionDelayGet()
Get the delay (seconds) that will occur before motion starts.
int32_t MotionHoldAxisNumberGet()
Gets the Axis number.
void MotionDelaySet(double seconds)
Set the time (seconds) that a motion will wait before starting.
void EStop()
E-Stop an axis.
double EStopTimeGet()
bool MotionAttributeMaskOnGet(RSIMotionAttrMask maskOn)
Check to see if a particular motion attribute mask is turned on.
void Map()
Writes the axis mapping relationship to the Controller.
bool AmpEnableGet()
Get the enabled state of all amplifiers.
void MovePVTF(const double *const position, const double *const velocity, const double *const time, const double *const feedforward, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
Move commanded by list of positions, velocities, times, and feedforward values.
double FeedRateGet()
Get the axis feed rate.
uint64_t MotionHoldUserAddressGet()
Gets the Motion Hold User Address.
Set the motion hold type.
int32_t MotionHoldGateNumberGet()
Returns the Motion Hold Gate number that the axis or multiaxis is set to.
void TriggeredModify()
Modify the currently executing motion to decelerate the Axis or MultiAxis to a zero velocity IDLE sta...
const char *const SourceNameGet(RSISource source)
void MotionIdSet(uint16_t id)
Set the Motion identifier.
int32_t MotionHoldUserMaskGet()
Gets the Motion Hold User Mask.
int32_t MotionHoldUserPatternGet()
Gets the Motion Hold user bit pattern.
void MotionHoldGateNumberSet(int32_t gateNumber)
Assigns the axis or multiaxis Motion Hold Gate number to the specified controller gate.
RSIMotionHoldType MotionHoldTypeGet()
Get the motion hold attribute type.
RSIState StateGet()
void Resume()
Resume an axis.
void StreamingOutputsClear()
uint64_t StatusBitsGet()
Return all the RMP firmware status bits as a 64-bit unsigned bitmask.
void MotionHoldGateSet(bool hold)
void FeedRateSet(double rate)
double MotionHoldTimeoutGet()
Get the motion hold timeout value.
void MotionHoldTimeoutSet(double seconds)
Set the motion hold timeout value.
Sets final velocity value in UserUnits (!!! only used if FINAL_VEL motion attribute is used !...
int32_t NumberGet()
Get the axis number.
RSISource SourceGet()
uint16_t MotionIdGet()
Get the motion identifier.
void EStopModify()
E-Stop with a deceleration rate.
void Unmap()
Removes the axis mapping relationship of the MultiAxis.
void MovePTF(const double *const position, const double *const time, const double *const feedforward, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
A move commanded by a list of position, time, and feedforward points.
bool IsMapped()
Check to see if the axis mapping is active on the firmware.
bool MotionDoneGet()
double StopTimeGet()
Get the axis count.
void EStopAbort()
E-Stop, then abort an axis.
Gets final velocity value (!!! only used if FINAL_VEL motion attribute is used !!!...
The RapidCodeMotion interface is implemented by Axis and MultiAxis .
static constexpr int32_t AmpEnableTimeoutMillisecondsDefault
Default timeout in milliseconds for AmpEnableSet() to wait for AMP_ACTIVE / OPERATION_ENABLED to go h...
RSIUserLimitLogic MotionHoldAxisLogicGet()
Get the logic when holding for Axis ActualPosition.
Get the currently executing motion ID.
static constexpr int32_t WaitForever
Use this value to wait indefinitely in methods which accept a waitTimeoutMilliseconds parameter.
void MotionAttributeMaskDefaultSet()
Restore the motion attribute mask to the RapidCode default.
Get the currently executing element ID (streaming motion).
int32_t PerformanceTimerFrequencyGet()
Gets the frequency of the performance counter.
int32_t PerformanceTimerCountGet()
Gets the current high performance counter value.
int32_t TimerFrequencyGet()
Get the number milliseconds per second.
int32_t TimerCountGet()
Gets the time since startup.
The RapidCodeOS object provides access to operating system (Windows) features. Accessible via MotionC...
void Trace(bool state)
void TraceInjectMessage(RSITrace traceLevel, const char *const message)
bool TraceMaskOnGet(RSITrace maskOn)
void TraceMaskOnSet(RSITrace maskOn)
void TraceMaskClear()
Clear the trace output mask.
void ErrorLogClear()
Clear the error log.
void TraceFileSet(const char *const fileName)
void TraceMaskOffSet(RSITrace maskOff)
const char *const VersionGet()
int32_t NumberGet()
void TraceFileClose()
Stops Logging to the file.
int32_t ErrorLogCountGet()
int32_t RSIVersionPatch()
Get the patch RSI version.
int32_t MpiVersionRelease()
Get the release MPI version.
int32_t MpiVersionMinor()
Get the minor MPI version.
const char *const ErrorMessageGet(RSIErrorMessage msg)
int32_t RSIVersionMicro()
Get the micro RSI version.
const char *const RsiErrorMessageGet(RSIErrorMessage msg)
int32_t RSIVersionMinor()
Get the minor RSI version.
int32_t RSIVersionMajor()
Get the major RSI version.
int32_t MpiVersionMajor()
Get the major MPI version.
bool WarningMsgCheck(RSIErrorMessage msg)
void Reserve(const size_t capacity)
Increases the size of the allocated storage of the vector to at least the specified size.
const size_t Size() const
Returns the number of elements in the vector.
const Type & operator[](const size_t index) const
Returns a const reference to the element at the location specified by the index.
const Type & Back() const
Returns a const reference to the last element in the vector.
void PushBack(Type &&element)
Appends the given element to the end of the vector.
Iterator begin() noexcept
Returns a RapidVectorIterator to the first element of the vector. The naming convention follows STL c...
Type & Front()
Returns a reference to the first element in the vector.
Iterator end() const noexcept
Returns a RapidVectorIterator to the element following the last element of the vector....
const Type & Front() const
Returns a const reference to the first element in the vector.
const Type & At(const size_t index) const
void PushBack(const Type &element)
Type & Back()
Returns a reference to the last element in the vector.
Returns a reference to the element at the location specified by the index.
A wrapper class for the C++ STL vector class that aims to maintain application binary interface....
RapidVector(RapidVector &&other) noexcept
Move constructor. Replaces contents with those of the other RapidVector.
RapidVectorIterator< RapidVector > Iterator
The iterator type for this RapidVector.
~RapidVector()
Destructs the vector and deallocates used storage.
RapidVector & operator=(const RapidVector &other)
Copy assignment operator. Replaces contents with the contents of the other RapidVector.
RapidVector(const RapidVector &other)
Copy constructor. Constructs a RapidVector as a deep-copy.
RapidVector(RapidVectorImplementation< Type > *)
Constructs a RapidVector with the given implementation. Intended for RSI internal use only.
void Clear()
Erases all elements from the vector.
void PopBack()
Removes the last element from the container. Calling PopBack() on an empty container results in undef...
RapidVector(const size_t size)
Constructs a vector with the specified size.
RapidVector & operator=(RapidVector &&other) noexcept
Move assignment operator. Replaces contents with those of the other RapidVector. The original content...
RapidVector()
Default constructor that constructs an empty vector.
RsiError(const RsiError ©From)
Copy constructor for RsiError.
char fileName[RSI_ERROR_TEXT_SIZE]
source file name
bool isWarning
static constexpr uint32_t RSI_ERROR_TEXT_SIZE
Error message text.
char shortText[RSI_ERROR_TEXT_SIZE]
Error short text.
int32_t lineNumber
Source code line number.
char functionName[RSI_ERROR_TEXT_SIZE]
Function name of the raised the error.
RSIErrorMessage number
Error number.
int32_t objectIndex
Object index (0-based index of the object that has the error).
static void MaskSet(RSITrace mask)
Sets the specified trace mask.
static void MaskOnSet(RSITrace maskOn)
static void InjectMessage(RSITrace traceLevel, const char *const message)
static bool MaskOnGet(RSITrace maskOn)
static void MaskOffSet(RSITrace maskOff)
static void FileClose()
static int32_t FileSet(const char *const fileName)
static void MaskClear()
Tracing allows for low level logs to be generated.
RSIFilterAlgorithm
Filter algorithms.
RSINetworkEniResult
NetworkEniGenerate return values.
RSIPDOType
Compensator output types.
RSIMathBlockOperation
MathBlock operations.
RSINetworkStartMode
Network start modes.
RSIMotorFeedbackFault
Feedbacks to use for Feedback Fault action.
RSIMotorStepperPulse
Pulse A or B.
RSINetworkNodeInitializationState
How far an EtherCAT node has progressed through network startup.
RSIAxisGantryType
How to combine Axis Feedback Positions.
RSIMotorDisableAction
Action for when a motor is disabled.
RSIEventType
Event Types or Status Bits.
RSIMotionType
RSINetworkSyncGroupState
State of an EtherCAT sync group (a set of nodes sharing one WKC-tolerant cyclic datagram).
RSIDataType
RSIUserLimitLogic
RSIMotorIoTypeMask
Possible mask bits for Motor I/O types.
RSIProcessorType
Controller's processor type.
RSIMotorStepperPulseType
Stepper pulse type.
RSINetworkInterfaceType
Network host interface type used for EtherCAT frame I/O.
Network start errors.
RSIMotorGeneralIo
Motor I/O bit numbers.
RSIMotionAttrMask
RSIFilterGainPIDCoeff
PID gain coefficients.
Trigger types for UserLimits.
RSINetworkOutputAddressType
Network output address types.
INtimeStatus
INtime status values.
RSIMotionHoldType
RSIControllerType
Controller type.
RSIMotorFaultMask
Mask values for several motor faults.
RSIHomeStage
Predefined Homing Stage sections.
RSIMotorBrakeMode
Brake modes.
RSIErrorMessage
All possible RSI Error Messages.
RSINetworkType
Type of Network topology.
RSIMotorIoType
Possible configurations for Motor I/O.
Feedback Positions for each Axis.
RSINodeType
Valid Node types.
RSISource
RSIMotorDedicatedIn
RSIMotorFeedback
Encoders per motor.
Dedicated Output bits per motor.
RSIOperationMode
DS402 modes of operation.
RSIPathPlanType
Path motion planning types.
Network technology type.
RSINetworkIndexType
RSINetworkStartupMethod
Network startup methods.
Address types for the dynamic status values of an EtherCAT node, for use with RapidCodeNetworkNode::A...
RSIFilterGainPIVCoeff
PIV gain coefficients.
RSIAxisMasterType
This namespace provides static methods and constants for user configuration in RMP applications....
int32_t ControllerIndex
The index of the controller to create.
static constexpr int32_t RmpThreadPriorityMaximum
The maximum thread priority for the real-time system.
static constexpr int32_t CpuAffinityDefault
The default value for CpuAffinity specifying no particular CPU core to run on.
char NodeName[PathLengthMaximum]
[Windows/INtime] Indicate the INtime node on which the RMP and RMPNetwork processes run.
static constexpr int32_t ControllerIndexDefault
The default value for ControllerIndex.
static constexpr char NodeNameDefault[]
The default INtime node name for NodeName (Windows only).
static constexpr int32_t RmpThreadPriorityNoRealTime
The thread priority where real time properties (scheduler and relative priorities) are not set.
static constexpr int32_t RmpThreadPriorityMinimum
The minimum thread priority for the real-time system.
static constexpr int32_t RmpThreadPriorityMaximumDefault
The default value for RmpThreadPriorityMax.
static constexpr int32_t RmpThreadPriorityRange
The priority range required for RMP and RMPNetwork threads. Minimum thread priority is this +1.
int32_t CpuAffinity
char NicPrimary[PathLengthMaximum]
Primary EtherCAT Network Interface (NIC) name.
[Linux] The maximum thread priority. All threads of the RMP and RMPNetwork will be based off of this....
CreationParameters()
Instantiate with every field set to its documented default value.
char NicSecondary[PathLengthMaximum]
Secondary EtherCAT Network Interface (NIC) name. Reserved for future use.
RSIDataType ProcessDataType
Data type for processing.
RSIDataType OutputDataType
Data type for Output. (optional).
uint64_t OutputAddress
Host memory address for Output. The MathBlock will write its result to this address....
uint64_t InputAddress0
RSIDataType InputDataType0
uint64_t InputAddress1
RSIDataType InputDataType1
NetworkStatus structure for EtherCAT network health monitoring.
uint32_t MissedCyclicFrameCount
Cumulative count of missed cyclic EtherCAT frames since network startup. Indicates communication reli...
RSINetworkInterfaceType InterfaceType
Host-side packet interface mechanism used for EtherCAT frame I/O (for example, INtime HPE2 or Linux A...
uint64_t EoeNodeToHostFrameCount
Cumulative count of EoE (Ethernet over EtherCAT) frames received from nodes by the host since network...
uint32_t AlStatus
Logical OR of AL Status registers (0x0130) from all nodes. A value of 8 indicates all nodes are Opera...
uint64_t EoeHostToNodeFrameCount
Cumulative count of EoE (Ethernet over EtherCAT) frames sent from the host toward nodes since network...
uint32_t CyclicFramePeriodUs
Most recent cyclic frame period in microseconds. Should match the configured sample rate.
int32_t SynchronizationErrorNs
Distributed Clock synchronization error in nanoseconds. Updated approximately every 16 samples....
uint32_t ActiveNodeCount
Number of nodes actively responding on the network. Compare against expected node count to detect dro...
Status of a single EtherCAT sync group.
RSINetworkSyncGroupState State
Current group state – see RSINetworkSyncGroupState for the meaning of each value.
bool DataValid
true when the group's cyclic data is trustworthy (WKC matches). The master clears this on a tolerated...
uint32_t Id
Sync group id (0 = default group).
uint64_t NonOperationalNodeMask
Bitmask (by node index, up to 64 nodes) of this group's member nodes NOT in OP. Bit i set means node ...
uint32_t NodeCount
Number of nodes assigned to this group.
uint32_t ToleratedWkcCount
Cumulative count of WKC mismatches tolerated for this group since network start. Increments while a W...
uint32_t ActualWkc
Most recent actual Working Counter. Less than ExpectedWkc while a group node is out of OP.
uint32_t ExpectedWkc
Expected Working Counter for this group's cyclic datagram.
uint32_t OperationalNodeCount
Number of this group's member nodes currently in the OP state. Equals NodeCount when healthy; drops b...
uint32_t SyncGroup
Sync group for this node. A non-zero group gives the node its own cyclic datagram and expected Workin...
Status structure for individual EtherCAT node diagnostics.
uint64_t SdoWriteCount
Cumulative count of every ServiceChannelWrite the network firmware serviced for this node since netwo...
uint64_t SdoWriteFailCount
Cumulative count of service channel writes for this node that finished unsuccessfully since network s...
uint64_t SdoReadFailCount
Cumulative count of service channel reads for this node (SDO uploads and register reads) that finishe...
Cumulative count of EoE (Ethernet over EtherCAT) frames received from this node by the host since net...
uint32_t SyncGroupId
Sync group this node belongs to, populated by the master from the ENI at startup. 0 = default group....
uint32_t AlStatus
EtherCAT AL Status register (0x0130) value. This is a snapshot value primarily useful for detecting u...
Cumulative count of EoE (Ethernet over EtherCAT) frames sent from the host to this node since network...
uint64_t SdoReadCount
Cumulative count of every ServiceChannelRead the network firmware serviced for this node since networ...
uint64_t AkdAsciiCount
Cumulative count of Kollmorgen AKD ASCII commands the network firmware serviced for this node since n...
RSINetworkNodeInitializationState InitializationState
How far this node has progressed through network startup. UNINITIALIZED means the node record is empt...
int32_t CoeEmergencyMessageNetworkCounter
Network counter value when the current CoeEmergencyMessage was received. Use to determine if the emer...
uint64_t CoeEmergencyMessage
CANopen over EtherCAT (CoE) emergency message. 8-byte value containing error code and additional data...
uint32_t AlStatusCode
EtherCAT AL Status Code register value. This is a snapshot value captured when the node reports an er...
bool Present
true if the node responded to the master's most recent AL-status read; false if it did not respond (p...
uint64_t AkdAsciiFailCount
Cumulative count of AKD ASCII commands for this node that failed since network start....
float Float
Single precision (32-bit) floating-point.
int64_t Int64
64-bit signed integer.
uint8_t UInt8
8-bit unsigned integer.
int8_t Int8
8-bit signed integer.
double Double
int32_t Int32
32-bit signed integer.
uint16_t UInt16
16-bit unsigned integer.
int16_t Int16
16-bit signed integer.
uint32_t UInt32
32-bit unsigned integer.
uint64_t UInt64
