◆ RSIMotionType
enum class RSIMotionType
strong
Motion Type Supports Preloaded Motion Supports Continuous Streaming Motion Method
PT ✅ ✅ MovePT
BSPLINE ✅ ✅ MovePT
SPLINE ✅ ❌ MovePT
BESSEL ✅ ❌ MovePT
BSPLINE2 ✅ ❌ MovePT
PVT ✅ ✅ MovePVT
PVAJT ✅ ❌ MovePVAJT
Streaming Motion, PT Streaming Motion
Enumerator
RSIMotionTypePT
Position-Time algorithm with continuous position but discontinuous velocity. Best for short time intervals.
RSIMotionTypeBSPLINE
3rd-order B-Spline algorithm with continuous velocity and acceleration; trajectory does not pass through control points.
RSIMotionTypeSPLINE
Spline algorithm with continuous velocity and acceleration; velocity may be discontinuous at the end unless final point is repeated.
RSIMotionTypeBESSEL
Bessel algorithm with continuous velocity but discontinuous acceleration; smoother than PT but less smooth than other splines.
RSIMotionTypeBSPLINE2
2nd-order B-Spline algorithm with continuous velocity but discontinuous acceleration; trajectory does not pass through control points.
RSIMotionTypePVT
Position-Velocity-Time algorithm with continuous position and velocity; acceleration and jerk are calculated between points but may be discontinuous at the control points, ensuring the specified values are met accurately.
RSIMotionTypeCONSTRAINED_SMOOTH1
(beta) acceleration constrained smoothing of PT points
RSIMotionTypeCONSTRAINED_SMOOTH2
RSIMotionTypePTF
Position-Time-Feedforward algorithm with continuous position but discontinuous velocity, includes feedforward control output.
RSIMotionTypePVTF
Position-Velocity-Time-Feedforward algorithm with continuous position and velocity, includes feedforward control output.
axis-motion-streaming-pt-whilestopping.cs, axis-motion-streaming-pt.cs, and io-sync-outputs.cs.
Definition at line 1179 of file rsienums.h.
