◆ UserLimitConfigSet() [2/2]
void UserLimitConfigSet ( int32_t number,
RSIUserLimitTriggerType triggerType,
RSIAction action,
int32_t actionAxis,
double duration,
bool singleShot )
UserLimitConfigSet configures a User Limit and enables it.
numberIndex of UserLimit (starts with 0)
triggerTypeuse ::RSIUserLimitTriggerType
actionUse ::RSIAction
actionAxisthe number of the Axis where the Action will occur.
durationIn seconds. Resolution of the duration is sample periods (default is 1ms).
singleShotIf true, the User Limit will be disabled after it triggers one time. The default behavior is false when means it will retrigger whenever conditions are met.
IO: User Limits
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
UserLimitConditionSet, UserLimitOutputSet
