| void MoveRelative | ( | const double *const | relativePosition, |
| const double *const | vel, | ||
| const double *const | accel, | ||
| const double *const | decel, | ||
| const double *const | jerkPct, | ||
| const double *const | finalVel ) |
| finalVel | Array of final velocities for each axis. MoveRelative with a final velocity array, instead of ending the point-to-point move at zero velocity. |
| relativePosition | An array of relative increments, positive or negative, in UserUnits. |
| vel | array of Maximum velocity, UserUnits/second. |
| accel | array of Maximum acceleration , UserUnits/second/second. (peak up to 2× accel when jerkPercent = 100, see below) |
| decel | array of Maximum deceleration , UserUnits/second/second. (peak up to 2× decel when jerkPercent = 100, see below) |
| jerkPct | array of Jerk Percent, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 . |
