◆ RSIControllerAddressType
enum class RSIControllerAddressType
strong
Enumerator
RSIControllerAddressTypeSAMPLE_COUNTER
Sample Counter.
RSIControllerAddressTypeSIGNATURE
Signature word.
RSIControllerAddressTypeUSER_BUFFER
First location in User Buffer.
RSIControllerAddressTypeRECORDER_BUFFER_POINTER
Pointer to the RecorderBuffer.
RSIControllerAddressTypeLIMIT_ENABLED_MASK
first 32-bits of LimitEnalbedMask
RSIControllerAddressTypeUSERLIMIT_STATUS
UserLimit status (must specify object index).
RSIControllerAddressTypeFRAME_SEND_RECEIVE_MICROSECONDS
programmable delay for packet send/receive (200 microseconds at <=1000Hz, 0 microseconds at >1000Hz, auto-set by SampleRateSet)
RSIControllerAddressTypeCOMPENSATOR_OUTPUT_TYPE
used to configure a compensator for single or additive output
RSIControllerAddressTypeCOMPENSATOR_COMPENSATOR_VALUE
the output of just that compensator no additive compensators
RSIControllerAddressTypeFIRMWARE_TIMING_DELTA
the latest time delta between the current RMP sample and the previous (microseconds)
RSIControllerAddressTypeNETWORK_TIMING_DELTA
the latest time delta between the current network packet send time and the previous (microseconds). MotionController::NetworkTimingEnableSet must be enabled
RSIControllerAddressTypeNETWORK_TIMING_RECEIVE_DELTA
the latest time delta between the current network packet receive time and the previous (microseconds). MotionController::NetworkTimingEnableSet must be enabled
RSIControllerAddressTypeMATHBLOCK_PROCESS_VALUE
the processed value of a math block (must specify object index)
RSIControllerAddressTypeFIRMWARE_NULL_INPUT
the null input value for the RMP firmware (used for restoring firmware input pointers to default)
RSIControllerAddressTypeFIRMWARE_NULL_OUTPUT
the null output value for the RMP firmware ( used for restoring firmware output pointers to default)
RSIControllerAddressTypeNETWORK_CLOCK_ENABLE
enable the Clock error collection feature 0 - Disabled 1 - Enabled
RSIControllerAddressTypeNETWORK_CLOCK_REFERENCE_ERROR_NS
error as determined between Ideal timestamp and Reference Clock timestamp (includes drift and jitter).
RSIControllerAddressTypeNETWORK_CLOCK_ADJUSTMENT_NS
adjustment value used for clock synchronization.
RSIControllerAddressTypeNETWORK_CLOCK_LINUX_ADJUSTMENT_NS
correction value used by linux.
RSIControllerAddressTypeNETWORK_CLOCK_INTIME_RELOAD_VALUE
hardware ticks between Intime kernel cycles.
RSIControllerAddressTypeNETWORK_CLOCK_MAX_RELOAD_VALUE_DELTA
max change to Intime Reload value per filter depth cycle.
RSIControllerAddressTypeNETWORK_CLOCK_FILTER_DEPTH
Filter Depth used by the clock alignment function.
RSIControllerAddressTypeNETWORK_CLOCK_KP
scaling factor for clock synchronization.
RSIControllerAddressTypeNETWORK_CLOCK_KI
RSIControllerAddressTypeNETWORK_CLOCK_KD
RSIControllerAddressTypeNETWORK_STATUS_ACTIVE_NODE_COUNT
Number of nodes that are actually powered on and responding.
RSIControllerAddressTypeNETWORK_STATUS_AL_STATUS
Logical OR of alStatus of all nodes (8 - Good/Operational).
RSIControllerAddressTypeNETWORK_STATUS_MISSED_CYCLIC_FRAME_COUNT
Cumulative count of missed cyclic frames.
RSIControllerAddressTypeNETWORK_STATUS_CYCLIC_FRAME_PERIOD_US
Collected every sample (microseconds).
RSIControllerAddressTypeNETWORK_STATUS_SYNCHRONIZATION_ERROR_NS
Typically collected every 16 samples (nanoseconds).
RSIControllerAddressTypeNETWORK_SYNC_GROUP_STATE
Sync group state (see RSINetworkSyncGroupState and Sync Groups). Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_SYNC_GROUP_EXPECTED_WKC
Expected working counter, summed over the sync group's cyclic process-data commands. Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_SYNC_GROUP_ACTUAL_WKC
Last received working counter, summed over the sync group's cyclic process-data commands. Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_SYNC_GROUP_DATA_VALID
1 when all the sync group's commands matched their working counter this cycle. Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_SYNC_GROUP_TOLERATED_WKC_COUNT
Cumulative count of tolerated working-counter mismatches for the sync group. Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_SYNC_GROUP_OPERATIONAL_NODE_COUNT
Member nodes currently in OP (recomputed rate-limited while the group is degraded). Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_SYNC_GROUP_NON_OPERATIONAL_NODE_MASK
64-bit bitmask of member node indexes not in OP (recomputed rate-limited while the group is degraded). Specify the sync group id as the object index.
RSIControllerAddressTypeNETWORK_NODE_SYNC_GROUP_ID
Sync group id the node belongs to (0 = default group; assigned at ENI generation, see Sync Groups). Specify the node index as the object index.
RSIControllerAddressTypeNETWORK_STATUS_EOE_HOST_TO_NODE_FRAME_COUNT
Network-wide cumulative EoE (Ethernet over EtherCAT) frames sent host to nodes since network start (64-bit). See MotionController::NetworkStatus.
RSIControllerAddressTypeNETWORK_STATUS_EOE_NODE_TO_HOST_FRAME_COUNT
Network-wide cumulative EoE (Ethernet over EtherCAT) frames received nodes to host since network start (64-bit). See MotionController::NetworkStatus.
RSIControllerAddressTypeNETWORK_STATE
The network state (RSINetworkState values) as reported by MotionController::NetworkStateGet. Record it to see exactly when the network left OPERATIONAL.
RSIControllerAddressTypeNETWORK_LAST_START_ERROR
The last network start error (RSINetworkStartError values) as reported by MotionController::LastNetworkStartErrorGet.
axis-motion-hold-via-address.cs, io-iopoint-user-buffer.cs, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, mathblock-pdo-copy.cs, recorder.cs, userlimit-command-position-direct.cs, userlimit-digital-input-one-condition.cs, userlimit-digital-input-two-condition.cs, userlimit-estop-store-position.cs, and userlimit-position-abort.cs.
Definition at line 405 of file rsienums.h.
