◆ MovePVT()
void MovePVT ( const double *const position,
const double *const velocity,
const double *const time,
int32_t pointCount,
int32_t emptyCount,
bool retain,
bool final )
MovePVT fits jerk profile segments through the list of position, velocity, time points. See Streaming Motion and PVT Streaming Motion for more information.
*positionArray of positions (p) to move through. (positions are in the UserUnits for each Axis)
Axis: [p0, p1, p2, ..., pn]
MultiAxis, assuming the Axis mapping is J0, J1, J2: [J0p0, J1p0, J2p0, ..., J0pn, J1pn, J2pn]
*velocityArray of velocities (v). (velocities are in UserUnits/second for each Axis)
Axis: [v0, v1, v2, ..., vn]
MultiAxis, assuming the Axis mapping is J0, J1, J2: [J0v0, J1v0, J2v0, ..., J0vn, J1vn, J2vn]
*timeArray of time durations for each point in seconds.
Minimum value is your MotionController sample period. Values must be a multiple of the sample period.
If each point should take one millisecond, your array would be: [0.001, 0.001, 0.001, etc.]
pointCountThe number of position/time points.
emptyCountThe number of motion frames (2 per point) that must be in the RMP firmware's buffer, below which triggers an OUT_OF_FRAMES E-Stop action.
The RapidCode library will load frames to the RMP firmware automatically, when the buffer gets low (1/4 of the MotionController::AxisFrameBufferSizeSet() value).
Set emptyCount high enough such that the duration of frames (2 per point) are greater than the value of EStopTimeGet/Set().
emptyCount must also be smaller than 20% of the MotionController::AxisFrameBufferSizeSet() value.
Using a value of 0 or -1 will result in undefined motion behavior if the firmware frame buffer is starved.
retainPoints kept, or not kept (must be True if you attempt a negative feedrate to back up on path).
finalTrue if this is the final streaming motion call, False if more streaming motion calls will occur before this call's points are finishes.
Performance
When starting from RSIStateIDLE, MovePT and MovePVT will internally call InterruptEnableSet().
Use MotionAttributeMaskOnSet() with RSIMotionAttrMask::RSIMotionAttrMaskNO_INTERRUPT_ENABLE to disable this behavior, which reduces the time it takes to start the motion.
Be sure to call InterruptEnableSet() once during initialization.
📜 Streaming Motion: PVT
/* Demonstrates PVT (Position-Velocity-Time) streaming motion.
PVT motion requires position, velocity, and time arrays.
The controller calculates acceleration for each segment.
Console.WriteLine("📜 Axis Streaming Motion: PVT");
// configure phantom axis
double[] velocities = [12.0, 10.0, 6.0]; // velocities for each position
double[] times = [0.1, 0.2, 0.1]; // time deltas (acceleration calculated by RMP)
axis.MovePVT(positions, // positions to reach
times, // time deltas
true); // if this is the last MovePVT call (true = final point, false = more points expected)
PVTmotionMultiAxis.cpp, and axis-motion-streaming-pvt.cs.
