◆ MotionHoldAxisNumberSet()
void MotionHoldAxisNumberSet ( int32_t number)
MotionHoldAxisNumberset sets the number of the Axis which has a Hold.
numberHold's Axis number.
Motion: Hold
/* This sample demonstrates how to hold motion based on another axis reaching a specified position.
Uses one axis to control when another axis's motion is released, useful for synchronized operations.
Console.WriteLine("📜 Motion Hold: via Position");
const double TRIGGER_POSITION = 1;
const int HOLDING_AXIS_TARGET = 2;
// get axes
Axis holdingAxis = controller.AxisGet(Constants.AXIS_0_INDEX);
Helpers.CheckErrors(holdingAxis);
Axis movingAxis = controller.AxisGet(Constants.AXIS_1_INDEX);
// configure phantom axes
Helpers.PhantomAxisReset(holdingAxis);
holdingAxis.AmpEnableSet(true, Constants.AMP_ENABLE_MS);
// configure motion hold - holdingAxis will be held until movingAxis reaches trigger position
bool movingAxisIsHardware = movingAxis.MotorTypeGet() != RSIMotorType.RSIMotorTypePHANTOM;
RSIMotionHoldType motionHoldType = movingAxisIsHardware ?
RSIMotionHoldType.RSIMotionHoldTypeAXIS_ACTUAL_POSITION : // AXIS_ACTUAL_POSITION for hardware axes
RSIMotionHoldType.RSIMotionHoldTypeAXIS_COMMAND_POSITION; // AXIS_COMMAND_POSITION for phantom axes
holdingAxis.MotionHoldTypeSet(motionHoldType);
holdingAxis.MotionHoldAxisNumberSet(movingAxis.NumberGet()); // specify which axis position to monitor
holdingAxis.MotionHoldAxisPositionSet(TRIGGER_POSITION); // position that will release the hold
holdingAxis.MotionHoldAxisLogicSet(RSIUserLimitLogic.RSIUserLimitLogicGE); // release when position >= trigger position
// enable motion hold and command motion
holdingAxis.MotionAttributeMaskOnSet(RSIMotionAttrMask.RSIMotionAttrMaskHOLD);
holdingAxis.MoveRelative(HOLDING_AXIS_TARGET); // this motion will be held
Console.WriteLine($"\tHolding axis commanded to move to {HOLDING_AXIS_TARGET}, but motion is held");
// move the trigger axis to release the hold
movingAxis.MoveRelative(MOVING_AXIS_TARGET);
Console.WriteLine($"\tMoving axis to {MOVING_AXIS_TARGET} to release hold...");
movingAxis.MotionDoneWait();
holdingAxis.MotionDoneWait();
Console.WriteLine($"\tHolding axis final position: {holdingAxis.CommandPositionGet()} (expected: {HOLDING_AXIS_TARGET})");
Console.WriteLine($"\tMoving axis final position: {movingAxis.CommandPositionGet()} (expected: {MOVING_AXIS_TARGET})");
Helpers.AbortMotionObject(holdingAxis);
const int AXIS_1_INDEX
Definition _constants.cs:21
RSIMotorType MotorTypeGet()
Get the motor type.
Definition rsi.h:6515
Sets the Axis position.
Set the motion hold type.
int32_t NumberGet()
Get the axis number.
RSIUserLimitLogic
Definition rsienums.h:717
RSIMotorType
Motor Type.
Definition rsienums.h:1395
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
MotionHoldAxisNumberGet()
axis-motion-hold-via-position.cs.
