◆ CreateFromSoftware() [1/3]
static MotionController * CreateFromSoftware ( )
static
CreateFromSoftware returns a pointer to the MotionController object it represents, and starts RMP.rta if it is not already running
(MotionController*) A static pointer to the controller specified.
Initialize the RMP EtherCAT motion controller.
// -- C++ -- //
Definition rsi.h:800
// -- C# -- //
The controller is initialized when this function is called. During the initialization process, if RMP.rta is not running, it will be started. The EtherCAT network is NOT started.
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
NetworkStart, NetworkStateGet, Delete
