◆ UserLimitCountSet()
void UserLimitCountSet ( int32_t userLimitCount)
UserLimitCountSet will configure the number of UserLimits processed by the controller firmware.
userLimitCountThe User Limit count.
IO: User Limits
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
The maximum number of UserLimits available can be checked with UserLimitCountMax(). UserLimitCountSet should be done after either setting AxisCountSet and/or starting the network (both of those can modify the AxisCount). Internally, RapidCode Axis objects will use UserLimits so it is important to only call UserLimitCountSet after all Axis object counts have been set, but before creating any Axis objects.
UserLimitCountGet, UserLimitCountMax, AxisCountSet
