◆ RecorderConfigureToTriggerOnMotion() [5/5]
void RecorderConfigureToTriggerOnMotion ( MultiAxis * multiAxis,
bool triggerOnMotion )
multiAxisMultiAxis object to trigger on.
triggerOnMotionA boolean value to set the trigger configuration. TRUE = trigger on Motion.
RecorderConfigureToTriggerOnMotion sets the recorder to trigger on motion. The recording will start when motion begins, and it will automatically stop when the Motion Done condition is true.
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
RecorderDataCountSet, RecorderTriggerOnMotionGet This is an overloaded member function, provided for convenience. It differs from the above function only in what argument(s) it accepts.
