A wrapper class for the C++ STL vector class that aims to maintain application binary interface. Provides some of the basic vector operations (with RapidCode naming conventions). More...
Public Types
typedef RapidVectorIterator< RapidVector > Iterator
 The iterator type for this RapidVector.
Functions
 RapidVector ()
 Default constructor that constructs an empty vector.
 RapidVector (const RapidVector &other)
 Copy constructor. Constructs a RapidVector as a deep-copy.
template<typename = typename std::enable_if_t<std::is_default_constructible_v<Type>>>
 RapidVector (const size_t size)
 Constructs a vector with the specified size.
 RapidVector (RapidVector &&other) noexcept
 Move constructor. Replaces contents with those of the other RapidVector.
 RapidVector (RapidVectorImplementation< Type > *)
 Constructs a RapidVector with the given implementation. Intended for RSI internal use only.
 ~RapidVector ()
 Destructs the vector and deallocates used storage.
Type & At (const size_t index)
 Returns a reference to the element at the location specified by the index.
const Type & At (const size_t index) const
 Returns a const reference to the element at the location specified by the index.
Type & Back ()
 Returns a reference to the last element in the vector.
const Type & Back () const
 Returns a const reference to the last element in the vector.
Iterator begin () const noexcept
 Returns a RapidVectorIterator to the first element of the vector. The naming convention follows STL conventions to allow use in foreach loops.
Iterator begin () noexcept
void Clear ()
 Erases all elements from the vector.
Iterator end () const noexcept
 Returns a RapidVectorIterator to the element following the last element of the vector. Do not attempt to dereference this iterator. The naming convention follows STL conventions to allow use in foreach loops.
Type & Front ()
 Returns a reference to the first element in the vector.
const Type & Front () const
 Returns a const reference to the first element in the vector.
RapidVector & operator= (const RapidVector &other)
 Copy assignment operator. Replaces contents with the contents of the other RapidVector.
RapidVector & operator= (RapidVector &&other) noexcept
 Move assignment operator. Replaces contents with those of the other RapidVector. The original contents of this are destructed.
Type & operator[] (const size_t index)
const Type & operator[] (const size_t index) const
void PopBack ()
 Removes the last element from the container. Calling PopBack() on an empty container results in undefined behavior (Like the STL vector).
void PushBack (const Type &element)
 Appends the given element to the end of the vector.
void PushBack (Type &&element)
void Reserve (const size_t capacity)
 Increases the size of the allocated storage of the vector to at least the specified size.
const size_t Size () const
 Returns the number of elements in the vector.
Description
template<typename Type>
class RSI::RapidCode::RapidVector< Type >
Unlike most templates, the method bodies are not provided here. RapidVector functions for template parameter types RSI does not explicitly provide and instantiate will not link. Presently, the only types defined for RapidVector are:
print-rttasks-summary.cpp.
Definition at line 13842 of file rsi.h.
