◆ CompensatorConfigSet() [2/4]
void CompensatorConfigSet ( int32_t compensatorNumber,
Axis * inputAxis,
RSIAxisMasterType inputAxisType,
double inputAxisMinimum,
double inputAxisMaximum,
double inputAxisDelta,
Axis * outputAxis,
RSICompensatorOutputType outputType,
const double *const table )
inputAxisTypeFeedback or position to follow
inputAxisThis specifies the axis of the first compensating Axis object. The position from this Axis will be used to index a single dimension of the compensation table. This number must correspond to a valid (existing) and enabled Axis on the controller.
inputAxisMinimumThe minimum feedback position (COUNTS) along the first compensation axis where compensation will occur.
inputAxisMaximumThe maximum feedback position (COUNTS) along the first compensation axis where compensation will occur.
inputAxisDeltaSpacing between compensation positions on the compensating axis. positionDelta must meet some specifications: positionDelta must be an exact multiple of the range (i.e. ((range.positionMax - range.positionMin) / positionDelta) must be an integer value). positionDelta must be greater than zero. positionDelta must be greater than (positionMax - positionMin).
outputAxisThis specifies the axis of the Axis to be compensated by the Compensator object. This number must correspond to a valid (existing) and enabled Axis on the controller.
outputTypeSets the behavior of a compensator. SINGLE: Only the most recent compensator configured to output on a specific axes will be applied ADDITIVE: The output of the compensator will be added with the result form the previously applied compensator on the specific axis.
tablethe points which will be written to the table
Motion: Compensator
const int INDEX_ZERO = 0;
const int INDEX_ONE = 1;
// print compensator info
// get rmp controller
// get & configure axes
// set compensator0
inputAxis: movingAxis,
inputAxisMinimum: MIN,
inputAxisMaximum: MAX,
inputAxisDelta: DELTA,
outputAxis: followerAxis,
table: table0);
// set compensator1
compensatorNumber: INDEX_ONE,
table: table1);
// get results
// print results
// verify compensation
const int AXIS_1_INDEX
Definition _constants.cs:21
Compensator output types.
Definition rsienums.h:1602
RSIAxisMasterType
Definition rsienums.h:1359
CompensatorCountSet
