◆ SoftwareNegLimitTriggerValueGet()
double SoftwareNegLimitTriggerValueGet ( )
SoftwareNegLimitTriggerValueGet returns the Software Negative Position limit value.
(double) The limit position, in User Units.
Axis: Configuration
// add phantom axis
// get phantom axis
Go to axis screen->Limits & Actions. In the image below, SoftwareNegLimitTriggerValueGet returns the value in the Trigger value box shown in the Negative (-) Software box. It currently triggers at -1125899890065410.
SoftwareNegLimitTriggerValueSet
