◆ SoftwareNegLimitActionSet()
void SoftwareNegLimitActionSet ( RSIAction action)
SoftwareNegLimitActionSet sets the action that will occur when the Software Negative Limit Event triggers.
actionAction taken on Limit trigger. A ::RSIAction value.
Note:
Axis: Configuration
// add phantom axis
// get phantom axis
Go to axis screen->Limits & Actions. In image below, SoftwareNegLimitActionSet sets the action type shown in the Negative (-) Software box. It is currently set to E_STOP.
SoftwareNegLimitActionGet
PathMotion.cpp, _helpers.cs, axis-config-phantom-axis.cs, config.h, and phantom-axis.cpp.
