◆ AxisCountGet()
int32_t AxisCountGet ( )
AxisCountGet returns the number of axes processing on the controller.
(int32_t) The axis count.
Part of the MotionController-Information method group.
Axis: Configuration
// add phantom axis
// get phantom axis
The standard default is now zero.
AxisCountSet
