◆ OriginPositionSet()
void OriginPositionSet ( double position)
OriginPositionSet sets the origin position of an axis. The origin position will effect both the Command and Actual positions of an axis. It is typically used in homing.
positionSet the origin to this value.
// set the origin position to 100000
axis.OriginPositionSet(100000);
It is better to Set the origin position, rather than the command and actual positions. Setting the origin wil set the HomeState to FALSE. This value is not set in Axis XML.
OriginPositionGet
axis-homing-akd-drive.cs.
