◆ MotionHoldUserPatternGet()
int32_t MotionHoldUserPatternGet ( )
MotionHoldUserPatternGet gets the bit pattern which will be compared for equality after the Mask has been evaluated.
The bitmask pattern
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
MotionHoldUserMaskSet()
