◆ HomeMethodSet()
void HomeMethodSet ( RSIHomeMethod method)
HomeMethodSet sets the method to be used for homing.
methodA ::RSIHomeMethod value.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Home
Master-based homing diagrams.
PathMotion.cpp, and axis-homing-master-based.cs.
