| void MoveRelative | ( | const double *const | relativePosition | ) |
Command a relative point-to-point S-Curve motion using Axis default values from DefaultVelocitySet, DefaultAccelerationSet, DefaultDecelerationSet, and DefaultJerkPercentSet
