11.1.1
AmpFaultActionSet()
void AmpFaultActionSet
action
AmpFaultActionSet sets the action to be performed when the Amp Fault triggers.
Note:
Available Actions are
Abort()
EStop()
Stop()
, None,
EStopAbort()
, and
EStopModify()
action
Action taken on Amp Fault event. A ::RSIAction value.
Axis: Configuration
// set
axis.
AmpEnableSet
false
// disable the amp
axis.
AmpFaultActionSet
.RSIActionABORT);
// set the action that will occur when there is an amp fault.
axis.
AmpFaultTriggerStateSet
false
// set the state of the amp fault.
axis.
AmpFaultDurationSet
(1);
// set the duration (seconds) required before the Amp Fault event triggers.
// get
bool
isEnabled = axis.
AmpEnableGet
faultAction = axis.
AmpFaultActionGet
bool
faultTriggerState = axis.
AmpFaultTriggerStateGet
double
faultDuration = axis.
AmpFaultDurationGet
Go to axis screen->Limits & Actions. In image below, AmpFaultActionSet sets the action type shown in the Amp Fault box. It is currently set to ABORT.
AmpFaultActionGet()
axis-config-ampfault.cs
axis-configuration.cpp
config.h
, and
phantom-axis.cpp
1.15.0
