◆ RSIMotionAttrMask
enum class RSIMotionAttrMask
strong
Enumerator
RSIMotionAttrMaskBEHAVIOR
(Default)
RSIMotionAttrMaskDELAY
Inserts a pause before the beginning of the move. MotionDelaySet contains the length of the delay.
RSIMotionAttrMaskRELATIVE
The position values for the move are interpreted relative to the current position.
RSIMotionAttrMaskID
(Default)
RSIMotionAttrMaskNO_HANDSHAKE
Does NOT wait for the handshake between the software and controller to begin the motion trajectory profile execution. This attribute is useful for faster function call return times, typically in single threaded or time critical applications.
RSIMotionAttrMaskEXPECTED_AXES
RSIMotionAttrMaskHOLD
Prevents the move from executing until a specific trigger condition is met. See MotionHold methods.
RSIMotionAttrMaskOUTPUT
Sets or clear bits after the move.
RSIMotionAttrMaskAUTOSTART_NOTIFY
RSIMotionAttrMaskNO_WAIT
Does NOT wait for the controller to acknowledge the commanded move, does NOT wait for the controller to return an error code, and applies the conditions for NO_HANDSHAKE. This attribute is useful for faster function call return times, typically in single threaded or time critical applications.
RSIMotionAttrMaskELEMENT_ID
(Default)
RSIMotionAttrMaskRETAIN
RSIMotionAttrMaskEMPTY_COUNT
(Default)
RSIMotionAttrMaskLOW_COUNT
RSIMotionAttrMaskAPPEND
Append motion.
RSIMotionAttrMaskAUTO_START
Auto Start.
RSIMotionAttrMaskSYNC_END
Synchronize end of motion for all axes.
RSIMotionAttrMaskSYNC_START
Synchronize start of motion for all axes.
RSIMotionAttrMaskREPEAT
Repeat.
RSIMotionAttrMaskMASTER_START
Master Start.
RSIMotionAttrMaskNO_BACKTRACK
No Backtrack.
RSIMotionAttrMaskNO_BACKTRACK_HOLD
No Backtrack Hold.
RSIMotionAttrMaskEVENT
Event.
RSIMotionAttrMaskFINAL_VEL
Final Vel.
RSIMotionAttrMaskNO_REVERSAL
No Reversal.
RSIMotionAttrMaskNO_INTERRUPT_ENABLE
Skip the InterruptEnableSet() in MovePT() and MovePVT() when motion is starting.
axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, and axis-motion-hold-via-position.cs.
Definition at line 1201 of file rsienums.h.
