strong |
| Enumerator | |
| RSINetworkStartErrorNETWORK_START_OK | No startup error. Network start completed successfully. |
| RSINetworkStartErrorNIC_PASSED | Invalid or unusable NIC/interface selection. Verify NIC name, interface state, and permissions. |
| RSINetworkStartErrorDEVICES_CONNECTED_POWERED | EtherCAT devices could not be reached. Verify cabling, power, and link status. |
| RSINetworkStartErrorDISCOVERED_ZERO_NODES | Discovery completed with zero nodes found. Verify topology and that slaves are powered. |
| RSINetworkStartErrorGENERAL_DISCOVERY_FAILURE | Discovery failed for an unspecified reason. Check network logs and retry discovery/start. |
| RSINetworkStartErrorNETWORK_INIT_FAILURE | Network startup failed after initial setup. Review network logs and configuration. |
| RSINetworkStartErrorINCORRECT_ENI_FORMAT | ENI data is invalid or unreadable. Regenerate or replace the ENI file. |
| RSINetworkStartErrorSLAVE_COMM_FAILED | Startup communication with one or more EtherCAT slaves failed. Verify wiring and slave health. |
| RSINetworkStartErrorMEMORY_CONFIG | Memory/configuration allocation failed during network startup. Restart and review network logs. |
| RSINetworkStartErrorETHERCAT_MASTER_STARTUP_ERROR | EtherCAT master failed to reach the required startup state. Check logs and network configuration. |
| RSINetworkStartErrorINTERNAL_RMP_ERROR | Internal controller/runtime error occurred while starting the network. Restart and collect logs. |
| RSINetworkStartErrorINTIME_OPEN_ERROR | INtime open/init operation failed. Verify INtime runtime status and platform setup. |
| RSINetworkStartErrorFAILED_TO_READ_PRODUCT_CODE | Failed to read Product Code from a slave device. Verify slave communication stability. |
| RSINetworkStartErrorFAILED_TO_READ_VENDOR_ID | Failed to read Vendor ID from a slave device. Verify slave communication stability. |
| RSINetworkStartErrorFAILED_TO_READ_REVISION | Failed to read Revision from a slave device. Verify slave communication stability. |
| RSINetworkStartErrorFAILED_TO_READ_SERIAL_NO | Failed to read Serial Number from a slave device. Verify slave communication stability. |
| RSINetworkStartErrorFAILED_TO_READ_STATION_ALIAS | Failed to read Station Alias from a slave device. Verify slave communication stability. |
| RSINetworkStartErrorTHREAD_SCHEDULING_OR_PRIORITY | Failed to set required thread scheduling/priority. Verify RT kernel support and privileges. |
| RSINetworkStartErrorETHERCAT_SAFETY_NOT_LICENSED | Safety configuration was detected but the required safety license is not present. |
| RSINetworkStartErrorETHERCAT_SAFETY_MAIN_DEVICE_NOT_DETECTED | Safety configuration was detected but no supported Safety MainDevice was found. |
| RSINetworkStartErrorUNSUPPORTED_NODE_DETECTED | An unsupported node on the network is blocking EtherCAT startup. |
| RSINetworkStartErrorENI_SAMPLE_RATE_MISMATCH | The ENI cycle time does not match the configured SampleRate. Regenerate the ENI after changing the sample rate. |
| RSINetworkStartErrorCPU_AFFINITY | Linux CPU affinity is not set to a single core. |
| RSINetworkStartErrorAF_XDP_SETUP_FAILED | AF_XDP was requested via UseAfXdp but socket/UMEM/NIC setup failed. |
| RSINetworkStartErrorNIC_SPECIFIED_NOT_FOUND | The NIC specified via MotionController::CreationParameters::NicPrimary could not be opened. No fallback probing was attempted. Verify the NIC/driver name and that the NIC is assigned to the real-time system. |
Definition at line 715 of file rsienums.h.
