RapidCodeInterrupt
Interface for objects which can use interrupts. More...
Functions
 Enable or disable interrupts.
void InterruptWake ()
 Wake any and all threads waiting for interrupts.
void InterruptMaskClear ()
void InterruptMaskAllSet ()
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t NumberGet ()
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Description
Definition at line 590 of file rsi.h.
