◆ RecorderRecordCountGet()
int32_t RecorderRecordCountGet ( )
RecorderRecordCountGet returns the number of records that are stored and ready for reading.
(int32_t) The number of records that have been recorded (not read).
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
RecorderRecordDataGet
