◆ UserLimitDisable()
void UserLimitDisable ( int32_t number)
UserLimitDisable disables the processing of a User Limit.
numberthe index of the User Limit (must be less than UserLimitCountMax)
IO: User Limits
// configure user limits
Helpers.CheckErrors(input0);
Helpers.CheckErrors(output0);
output0.Set(false);
number: 0,
conditionNumber: 0,
number: 0,
actionAxis: 0,
duration: 0);
number: 0,
enabled: true);
if (output0.Get())
if (!output0.Get())
output0.Set(false);
void Set(bool state)
bool Get()
Definition rsi.h:12981
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Trigger types for UserLimits.
Definition rsienums.h:758
UserLimitConfigSet, UserLimitConditionSet
