◆ MoveSCurve() [3/3]
void MoveSCurve ( double position,
double vel,
double accel,
double decel,
double jerkPct,
double finalVel )
MoveSCurve with a final velocity, instead of ending the point-to-point move at zero velocity.
finalVelFinal velocity. Command a point-to-point S-Curve motion.
positionTarget Position in UserUnits.
velMaximum velocity, UserUnits/second.
accelAverage acceleration , UserUnits/second/second. (peak up to 2× accel when jerkPercent = 100, see below)
decelAverage deceleration , UserUnits/second/second. (peak up to 2× decel when jerkPercent = 100, see below)
jerkPctJerk Percent, which defines the percentage of acceleration time which is smoothed, 0.0 to 100.0 .
MoveSCurve command a point-to-point motion, with an S-Curve velocity profile. This type of motion has an "S" shape to the acceleration and deceleration phases. It uses the JerkPercent parameter to decide how much of the acceleration and deceleration phases is curved. A JerkPercent of zero produces a trapezoidal profile.
Part of the Motion method group. See the S-Curve Motion concept page for more information.
SCurveMotion
Motion Scope:
An S-Curve velocity (non-constant acceleration) profile shown below:
S-Curve Motion, MoveSCurve, MoveRelative, MoveVelocity, MovePT, MovePVT DefaultVelocitySet, DefaultAccelerationSet, DefaultDecelerationSet, DefaultJerkPercentSet
