The RapidCodeMotion interface is implemented by Axis and MultiAxis . More...
Functions
int32_t NumberGet ()
 Get the axis number.
int32_t AxisCountGet ()
 Get the axis count.
void TriggeredModify ()
 Modify the currently executing motion to decelerate the Axis or MultiAxis to a zero velocity IDLE state.
void Stop ()
 Stop an axis.
void Resume ()
 Resume an axis.
void EStop ()
 E-Stop an axis.
void EStopAbort ()
 E-Stop, then abort an axis.
void EStopModify ()
 E-Stop with a deceleration rate.
void EStopModifyAbort ()
void Abort ()
void ClearFaults ()
int32_t AmpEnableSet (bool enable, int32_t ampActiveTimeoutMilliseconds=AmpEnableTimeoutMillisecondsDefault, bool overrideRestrictedState=false)
bool AmpEnableGet ()
 Get the enabled state of all amplifiers.
void Map ()
 Writes the axis mapping relationship to the Controller.
void Unmap ()
 Removes the axis mapping relationship of the MultiAxis.
bool IsMapped ()
 Check to see if the axis mapping is active on the firmware.
void FeedRateSet (double rate)
double FeedRateGet ()
 Get the axis feed rate.
RSIState StateGet ()
RSISource SourceGet ()
const char *const SourceNameGet (RSISource source)
int32_t MotionDoneWait (int32_t waitTimeoutMilliseconds=WaitForever)
bool MotionDoneGet ()
bool StatusBitGet (RSIEventType bitMask)
uint64_t StatusBitsGet ()
 Return all the RMP firmware status bits as a 64-bit unsigned bitmask.
void InterruptWake ()
 Wake all threads waiting for an interrupt on this Axis.
double StopTimeGet ()
void StopTimeSet (double seconds)
double EStopTimeGet ()
void EStopTimeSet (double seconds)
double MotionDelayGet ()
 Get the delay (seconds) that will occur before motion starts.
void MotionDelaySet (double seconds)
 Set the time (seconds) that a motion will wait before starting.
uint16_t MotionIdGet ()
 Get the motion identifier.
void MotionIdSet (uint16_t id)
 Set the Motion identifier.
uint16_t MotionIdExecutingGet ()
 Get the currently executing motion ID.
uint16_t MotionElementIdExecutingGet ()
 Get the currently executing element ID (streaming motion).
double MotionFinalVelocityGet ()
 Gets final velocity value (!!! only used if FINAL_VEL motion attribute is used !!!).
void MotionFinalVelocitySet (double finalVelocity)
 Sets final velocity value in UserUnits (!!! only used if FINAL_VEL motion attribute is used !!!).
RSIMotionHoldType MotionHoldTypeGet ()
 Get the motion hold attribute type.
void MotionHoldTypeSet (RSIMotionHoldType type)
 Set the motion hold type.
int32_t MotionHoldGateNumberGet ()
 Returns the Motion Hold Gate number that the axis or multiaxis is set to.
void MotionHoldGateNumberSet (int32_t gateNumber)
 Assigns the axis or multiaxis Motion Hold Gate number to the specified controller gate.
double MotionHoldTimeoutGet ()
 Get the motion hold timeout value.
void MotionHoldTimeoutSet (double seconds)
 Set the motion hold timeout value.
bool MotionHoldGateGet ()
void MotionHoldGateSet (bool hold)
 Set the Motion Hold Gate.
int32_t MotionHoldAxisNumberGet ()
 Gets the Axis number.
void MotionHoldAxisNumberSet (int32_t number)
double MotionHoldAxisPositionGet ()
 Gets the Axis position.
void MotionHoldAxisPositionSet (double position)
 Sets the Axis position.
RSIUserLimitLogic MotionHoldAxisLogicGet ()
 Get the logic when holding for Axis ActualPosition.
void MotionHoldAxisLogicSet (RSIUserLimitLogic logic)
uint64_t MotionHoldUserAddressGet ()
 Gets the Motion Hold User Address.
void MotionHoldUserAddressSet (uint64_t address)
int32_t MotionHoldUserMaskGet ()
 Gets the Motion Hold User Mask.
void MotionHoldUserMaskSet (int32_t holdMask)
int32_t MotionHoldUserPatternGet ()
 Gets the Motion Hold user bit pattern.
void MotionHoldUserPatternSet (int32_t pattern)
void MotionAttributeMaskDefaultSet ()
 Restore the motion attribute mask to the RapidCode default.
bool MotionAttributeMaskOnGet (RSIMotionAttrMask maskOn)
 Check to see if a particular motion attribute mask is turned on.
void MotionAttributeMaskOnSet (RSIMotionAttrMask maskOn)
void MotionAttributeMaskOffSet (RSIMotionAttrMask maskOff)
void MovePT (RSIMotionType type, const double *const position, const double *const time, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
void MovePVT (const double *const position, const double *const velocity, const double *const time, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
void MovePVAJT (const double *const position, const double *const velocity, const double *const acceleration, const double *const jerk, const double *const time, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
void MovePTF (const double *const position, const double *const time, const double *const feedforward, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
 A move commanded by a list of position, time, and feedforward points.
void MovePVTF (const double *const position, const double *const velocity, const double *const time, const double *const feedforward, int32_t pointCount, int32_t emptyCount, bool retain, bool final)
 Move commanded by list of positions, velocities, times, and feedforward values.
void StreamingOutputAdd (int32_t onMask, int32_t offMask, uint64_t address)
void StreamingOutputAdd (int32_t onMask, int32_t offMask, uint64_t address, int32_t ptPointIndex)
 Applies the on and off bitmasks to the controller's memory address when the motion reaches the specified streaming point index. Used to toggle Digital Outputs and/or memory.
void StreamingOutputAdd (RapidCode::IOPoint *point, bool on)
void StreamingOutputAdd (RapidCode::IOPoint *point, bool on, int32_t ptPointIndex)
 Sets the state of the specified IOPoint when the motion reaches the specified streaming point index.
void StreamingOutputsClear ()
void StreamingOutputsEnableSet (bool enable)
void InterruptMaskClear ()
void InterruptMaskAllSet ()
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Attributes
MotionController * rsiControl
Static Attributes
static constexpr int32_t AmpEnableTimeoutMillisecondsDefault = 500
 Default timeout in milliseconds for AmpEnableSet() to wait for AMP_ACTIVE / OPERATION_ENABLED to go high.
static constexpr int32_t WaitForever = -1
 Use this value to wait indefinitely in methods which accept a waitTimeoutMilliseconds parameter.
Description
_helpers.cs.
Definition at line 5505 of file rsi.h.
