◆ SoftwareNegLimitTriggerValueSet()
void SoftwareNegLimitTriggerValueSet ( double triggerValue)
SoftwareNegLimitTriggerValueSet sets the Software Negative Position limit value.
triggerValueThe limit position, in units.
Axis: Configuration
// add phantom axis
// get phantom axis
Go to axis screen->Limits & Actions. In the image below, SoftwareNegLimitTriggerValueSet sets the value in the Trigger value box shown in the Negative (-) Software box. It currently triggers at -1125899890065410.
SoftwareNegLimitTriggerValueGet
