The IO object provides an interface to the inputs and outputs of a network node. More...
Functions
const char *const UserLabelGet ()
 Get the IO User defined Label.
void UserLabelSet (const char *const userLabel)
 Set the IO User defined Label.
bool IOExists ()
 IOExists validates your IO object is an IO Node.
int32_t NumberGet ()
 Get the zero-based IO number.
bool DigitalInGet (int32_t digitalInNumber)
 Get the state of a digital input bit.
bool DigitalOutGet (int32_t digitalOutNumber)
 Get the state of a Digital Output bit.
void DigitalOutSet (int32_t digitalOutNumber, bool outValue)
 Set the state of a digital output bit.
int32_t AnalogInGet (int32_t analogChannel)
int32_t AnalogOutGet (int32_t analogChannel)
 Get the value of an analog output.
void AnalogOutSet (int32_t analogChannel, int32_t analogValue)
 Set the value of an analog output.
int32_t MpiVersionMajor ()
 Get the major MPI version.
int32_t MpiVersionMinor ()
 Get the minor MPI version.
int32_t MpiVersionRelease ()
 Get the release MPI version.
int32_t RSIVersionMajor ()
 Get the major RSI version.
int32_t RSIVersionMinor ()
 Get the minor RSI version.
int32_t RSIVersionMicro ()
 Get the micro RSI version.
int32_t RSIVersionPatch ()
 Get the patch RSI version.
int32_t ErrorLogCountGet ()
void ErrorLogClear ()
 Clear the error log.
void Trace (bool state)
void TraceMaskClear ()
 Clear the trace output mask.
void TraceFileClose ()
 Stops Logging to the file.
Attributes
NetworkNode * NetworkNode
 Gets the parent NetworkNode object.
MotionController * rsiControl
Description
An IO node can have various combinations of digital or analog inputs and outputs. IO objects contain a RapidCodeNetworkNode.
UserLimitDigitalInputAction.cpp.
Definition at line 13473 of file rsi.h.
