◆ RecorderRecordDataRetrieveBulk()
int32_t RecorderRecordDataRetrieveBulk ( int32_t recorderNumber,
int32_t recordCount )
RecorderRecordDataRetrieveBulk retrieves a group of records from the Recorder, and stores it in the MotionController.
recorderNumberIndex of the recorder. 0 to (MotionController::RecorderCountMaximum - 1) valid.
recordCountThe count of records to be read. 1 to 1024. Internally limited.
The number of records which were retrieved from the Recorder to Controller memory.
Monitoring: Recorder
const int INPUT_INDEX = 0;
// configure phantom axis
// configure recorder
// start recording
controller.RecorderStart();
// retrieve recorded data
// stop and reset recorder
Definition rsi.h:12981
RSIDataType
Definition rsienums.h:784
Definition rsienums.h:451
Definition rsi.h:464
double Double
Definition rsi.h:473
int32_t Int32
32-bit signed integer.
Definition rsi.h:470
RecorderRecordDataDoubleGet
