◆ AxisFrameBufferSizeDefault
int32_t AxisFrameBufferSizeDefault = 1024
staticconstexpr
The Axis frame buffer size is the number of frames that can be stored in the RMP Axis frame buffer. This is most useful for streaming motion (MovePT, MovePVT) when RapidCode will automatically load frames as needed, which is triggered when the Axis frame buffer is below 25% of its capacity. Keep in mind each PT or PVT point requires 2 frames.
AxisFrameBufferSizeGet, AxisFrameBufferSizeSet
gcode-motion.cs, gcode-units.cs, path-3d-points.cs, and path-motion.cs.
Definition at line 860 of file rsi.h.
