Represents an EtherCAT node / SubDevice (Drive, I/O Block, etc) on the network. This class provides an interface to all digital and analog I/O on the node, as well as the ability to read and write SDOs. Get or create a NetworkNode using MotionController::NetworkNodeGet or the Axis property, NetworkNode.
More...
bool | Exists () |
| | Returns true if this NetworkNode exists on a physical network.
RSINodeType | TypeGet () |
| | Get the node type, as determined by the Vendor ID and Product Code.
bool | IsEtherCAT () |
| | Check if the node is EtherCAT.
| bool | IsAKDASCIICommandSupported () |
| | Check whether this node accepts Kollmorgen ASCII commands through AKDASCIICommand().
bool | IsSynqNet () |
| | Check if the node is SynqNet.
| bool | HasIO () |
| | Check if the node has any analog or digital inputs or outputs.
| bool | DigitalInGet (int32_t digitalInNumber) |
| | Get the state of a digital input.
| bool | DigitalOutGet (int32_t digitalOutNumber) |
| | Get the state of a digital output.
| void | DigitalOutSet (int32_t digitalOutNumber, bool state) |
| | Set the state of a digital output.
| int32_t | AnalogInGet (int32_t analogChannel) |
| | Get the value of an analog input.
| int32_t | AnalogOutGet (int32_t analogChannel) |
| | Get the value of an analog output.
| void | AnalogOutSet (int32_t analogChannel, int32_t analogValue) |
| | Set the value of an analog output.
| int32_t | DigitalInCountGet () |
| | Get the number of digital inputs on this node.
| int32_t | DigitalOutCountGet () |
| | Get the number of digital outputs on this node.
| int32_t | AnalogInCountGet () |
| | Get the number of analog inputs on this node.
| int32_t | AnalogOutCountGet () |
| | Get the number of analog outputs on this node.
int32_t | SegmentCountGet () |
| | Get the number of segments on this node.
int32_t | SegmentDigitalInCountGet (int32_t segmentNumber) |
| | Get the number of digital inputs on a segment.
int32_t | SegmentDigitalOutCountGet (int32_t segmentNumber) |
| | Get the number of digital outputs on a segment.
int32_t | SegmentAnalogInCountGet (int32_t segmentNumber) |
| | Get the number of analog inputs on a segment.
int32_t | SegmentAnalogOutCountGet (int32_t segmentNumber) |
| | Get the number of analog outputs on a segment.
int32_t | SegmentIDGet (int32_t segmentNumber) |
| | Get the ID number of a segment.
| uint64_t | DigitalInAddressGet (int32_t bitNumber) |
| | Get the host address for a Node's digital input.
| int32_t | DigitalInMaskGet (int32_t bitNumber) |
| | Get the bitwise mask for a Node's digital input.
| uint64_t | DigitalOutAddressGet (int32_t bitNumber) |
| | Get the host address for a Node's digital output.
| int32_t | DigitalOutMaskGet (int32_t bitNumber) |
| | Get the bitwise mask for a Node's digital output.
| uint64_t | AnalogInAddressGet (int32_t channel) |
| | Get the host address for a Node's analog input.
| int32_t | AnalogInMaskGet (int32_t channel) |
| | Get the bitwise mask for a Node's analog input.
| uint64_t | AnalogOutAddressGet (int32_t channel) |
| | Get the host address for a Node's analog output.
| int32_t | AnalogOutMaskGet (int32_t channel) |
| | Get the bitwise mask for a Node's analog output.
| int32_t | DigitalInNetworkIndexGet (int32_t digitalInNumber) |
| | Get the global network input index for a node's digital input channel.
| int32_t | DigitalOutNetworkIndexGet (int32_t digitalOutNumber) |
| | Get the global network output index for a node's digital output channel.
| int32_t | AnalogInNetworkIndexGet (int32_t analogChannel) |
| | Get the global network input index for a node's analog input channel.
| int32_t | AnalogOutNetworkIndexGet (int32_t analogChannel) |
| | Get the global network output index for a node's analog output channel.
| int32_t | ServiceChannelRead (int32_t index, int32_t subIndex, int32_t byteCount, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault) |
| | Read a 32-bit integer value from the SDO.
| const char *const | ServiceChannelReadString (int32_t index, int32_t subIndex, int32_t byteCount, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault) |
| | Read a string from the SDO.
| RapidVector< uint8_t > | ServiceChannelReadBytes (int32_t index, int32_t subIndex, int32_t byteCount, uint32_t timeoutMilliseconds) |
| | Read a number of bytes from the SDO.
| void | ServiceChannelWrite (int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault) |
| | Write a number in the SDO.
| void | ServiceChannelWrite (int32_t index, int32_t subIndex, int32_t byteCount, const char *const stringValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault) |
| | Write a string in the SDO.
| void | ServiceChannelWrite (int32_t index, int32_t subIndex, int32_t byteCount, RapidVector< uint8_t > bytes, uint32_t timeoutMilliseconds) |
| | Write an array of bytes to the SDO.
| char * | AKDASCIICommand (const char *const command) |
| | Send an ASCII command to a supported Kollmorgen drive.
void | ClearFaults (int32_t axisNumber) |
| | Clear the faults for a specific axis number on this node.
uint32_t | VendorIdGet () |
| | Get the EtherCAT vendor ID.
| const char *const | NameGet () |
| | Get the Node's Short Name that appears on NodeInfo.xml.
| const char *const | ProductNameGet () |
| | Get the node's product name from NodeInfo.xml or CustomNodeInfo.xml.
| const char *const | VendorNameGet () |
| | Get the node's vendor name from NodeInfo.xml or CustomNodeInfo.xml.
uint32_t | ProductCodeGet () |
| | Get the EtherCAT product code.
uint32_t | RevisionGet () |
| | Get the EtherCAT hardware revision.
uint32_t | StationAliasGet () |
| | Get the EtherCAT station alias.
const char *const | SerialNumberGet () |
| | Get the serial number as text.
uint32_t | AxisCountGet () |
| | Get the number of Axis objects associated with this NetworkNode.
uint16_t | StatusWordGet (int32_t axisIndex) |
| | Get the DS402 status word.
| Status | StatusGet () |
| | Get the node's status details.
| void | StatusClear () |
| | Clear the node's status values.
| uint64_t | AddressGet (RSINetworkNodeAddressType addressType) |
| | Get the host address for one of this node's status values.
| RSIDataType | AddressDataTypeGet (RSINetworkNodeAddressType addressType) |
| | Get the data type for one of this node's status addresses.
| Config | ConfigGet () |
| | Get the node's configuration.
| void | ConfigSet (const Config &config) |
| | Set the node's configuration.
| const char *const | VersionGet () |
| | Get the RSI RapidCode version.
int32_t | MpiVersionMajor () |
| | Get the major MPI version.
int32_t | MpiVersionMinor () |
| | Get the minor MPI version.
int32_t | MpiVersionRelease () |
| | Get the release MPI version.
int32_t | RSIVersionMajor () |
| | Get the major RSI version.
int32_t | RSIVersionMinor () |
| | Get the minor RSI version.
int32_t | RSIVersionMicro () |
| | Get the micro RSI version.
int32_t | RSIVersionPatch () |
| | Get the patch RSI version.
| int32_t | NumberGet () |
| | Get the zero-based index of this object.
| int32_t | ErrorLogCountGet () |
| | Get the number of software errors in the error log.
| const RsiError *const | ErrorLogGet () |
| | Get the next RsiError in the log.
| void | ErrorLogClear () |
| | Clear the error log.
| void | ThrowExceptions (bool state) |
| | Configure a class to throw exceptions.
const char *const | RsiErrorMessageGet (RSIErrorMessage msg) |
| | Get the RSI-specific error message text for a specific RSIErrorMessage.
const char *const | ErrorMessageGet (RSIErrorMessage msg) |
| | Get the detailed text message for an RSIErrorMessage.
bool | WarningMsgCheck (RSIErrorMessage msg) |
| | Check to see if an RSIErrorMessage is a warning (true) or not (false).
| void | Trace (bool state) |
| | Enables/Disables trace output.
| void | TraceMaskOnSet (RSITrace maskOn) |
| | Turn on a particular trace output mask.
| bool | TraceMaskOnGet (RSITrace maskOn) |
| | Check to see if a particular trace output mask is turned on.
| void | TraceMaskOffSet (RSITrace maskOff) |
| | Turn off a particular trace output mask.
| void | TraceMaskClear () |
| | Clear the trace output mask.
| void | TraceFileSet (const char *const fileName) |
| | Channels Tracing messages to specified file.
| void | TraceFileClose () |
| | Stops Logging to the file.
| void | TraceInjectMessage (RSITrace traceLevel, const char *const message) |
| | Add a message to the Trace Log.
static constexpr uint32_t | SDOTimeoutMillisecondsDefault = 100 |
| | Default time to wait when reading or writing an SDO with ServiceChannelRead() or ServiceChannelWrite().
User Labels
| static constexpr int32_t | UserLabelCharacterCountMaximum = 64 |
| static constexpr int32_t | IoUserLabelBufferBytes = 65536 |
| const char *const | UserLabelGet () |
| | Get this node's user defined label.
| void | UserLabelSet (const char *const userLabel) |
| | Set this node's user defined label.
| const char *const | DigitalInUserLabelGet (int32_t digitalInNumber) |
| | Get the user defined label of one of this node's digital inputs.
| void | DigitalInUserLabelSet (int32_t digitalInNumber, const char *const userLabel) |
| | Set the user defined label of one of this node's digital inputs.
| const char *const | DigitalOutUserLabelGet (int32_t digitalOutNumber) |
| | Get the user defined label of one of this node's digital outputs.
| void | DigitalOutUserLabelSet (int32_t digitalOutNumber, const char *const userLabel) |
| | Set the user defined label of one of this node's digital outputs.
| const char *const | AnalogInUserLabelGet (int32_t analogChannel) |
| | Get the user defined label of one of this node's analog inputs.
| void | AnalogInUserLabelSet (int32_t analogChannel, const char *const userLabel) |
| | Set the user defined label of one of this node's analog inputs.
| const char *const | AnalogOutUserLabelGet (int32_t analogChannel) |
| | Get the user defined label of one of this node's analog outputs.
| void | AnalogOutUserLabelSet (int32_t analogChannel, const char *const userLabel) |
| | Set the user defined label of one of this node's analog outputs.
| uint64_t | IoUserLabelGenerationGet () |
| | Get the change counter that says whether any I/O point user label on this controller changed.
