◆ MotionHoldTypeSet()
void MotionHoldTypeSet ( RSIMotionHoldType type)
MotionHoldTypeSet sets the motion hold type.
typeUse RSIMotionAttrHoldType.
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
To hold execution of motion, you can use Motion Hold.
If you need to hold execution based on a particular bit turning ON or OFF, use RSIMotionAttrHoldTypeUSER_ADDRESS. With RSIMotionAttrHoldTypeUSER_ADDRESS, the logic in the MotionController firmware goes something like this:
andResult = ( userAddressValue & mask);
if (andResult == pattern)
releaseHold();
If using RSIMotionAttrHoldTypeUSER_ADDRESS or GATE, be sure to set RSIMotionAttrMaskHOLD before starting motion.
If using RSIMotionAttrHoldTypeAXIS_POSITION_COMMAND be sure to set RSIMotionAttrMaskHOLD or LESS before starting motion.
MotionHoldTypeGet
MotionHoldReleasedBySoftwareAddress.cpp, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, and axis-motion-hold-via-position.cs.
