NetworkNodeGet returns a pointer to a RapidCodeNetworkNode object using its node number and initializes its internals.
nodeNumber
The reference number of the node. The first network node is the 0th Node.
(RapidCodeNetworkNode*) A pointer to the NetworkNode specified.
The RMP assigns a logical number to each network node that it encounters during initialization. This number starts with 0 and will be incremented for each node discovered.
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
