◆ AmpEnableGet()
bool AmpEnableGet ( )
AmpEnableGet returns the state of the Amp Enable Output.
(int32_t) 0 = amp is disabled, 1 = amp is enabled.
Part of the Dedicated I/O method group.
Axis: Configuration
// set
axis.AmpEnableSet(false); // disable the amp
axis.AmpFaultActionSet(RSIAction.RSIActionABORT); // set the action that will occur when there is an amp fault.
axis.AmpFaultTriggerStateSet(false); // set the state of the amp fault.
axis.AmpFaultDurationSet(1); // set the duration (seconds) required before the Amp Fault event triggers.
// get
bool isEnabled = axis.AmpEnableGet();
RSIAction faultAction = axis.AmpFaultActionGet();
bool faultTriggerState = axis.AmpFaultTriggerStateGet();
double faultDuration = axis.AmpFaultDurationGet();
Go to axis screen->Dedicated I/O tab. The High/Low state next to Amp Enable is the result of the AmpEnableGet function.
For the RMP DedicatedIOGet(RSIMotorDedicatedIn::RSIMotorDedicatedInAMP_ACTIVE) is a more accurate state of the physical drive rather than logical axis.
AmpEnableSet
axis-config-ampfault.cs, and io-dedicated.cs.
