◆ UserLimitInterruptUserDataAddressSet()
void UserLimitInterruptUserDataAddressSet ( int32_t number,
uint32_t userDataIndex,
uint64_t address )
UserLimitInterruptUserDataAddressSet will allow you to specify set the user data object address that will be recorded when the user limit specified triggers.
Your specified address can be any address, including all RSIAxisAddressType addresses.
numberNumber of the UserLimit.
userDataIndexThere are only 5 User Data objects. (userDataIndex is zero ordinate and must be a value from 0 to 4)
addressThis is the address of the object that you want to keep track of when the User Limit interrupt triggers..
IO: User Limits
Console.WriteLine("šŸ“œ User Limit: Command Position Direct Set");
const int DURATION = 0;
// configure user limits
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ FIRST USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_FIRST,
conditionNumber: 0,
actionAxis: axis.NumberGet(),
duration: DURATION,
singleShot: ONE_SHOT);
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ SECOND USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_SECOND,
conditionNumber: 0,
userLimitMask: 1,
limitValueUInt32: 1);
conditionNumber: 1,
limitValueDouble: 0.0);
actionAxis: 0,
duration: 0,
// start motion
axis.ClearFaults();
axis.Abort();
axis.ClearFaults();
Console.WriteLine($"āŒ Error: {e.Message}");
number: userLimitIndex,
bool done = false;
int interruptCount = 0;
while (!done)
interruptCount++;
switch (eventType)
done = true;
Console.WriteLine($"\nāœ“ Completed - received {interruptCount} interrupts");
default:
NetworkNode * NetworkNode
Definition rsi.h:7077
int32_t NumberGet()
Get the axis number.
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1102
RSIUserLimitLogic
Definition rsienums.h:771
Definition rsienums.h:1256
Definition rsienums.h:451
Trigger types for UserLimits.
Definition rsienums.h:758
userlimit-command-position-direct.cs.
