◆ Get() [1/2]
MotionController * Get ( )
static
Description: Get a MotionController object. This will NOT start the RMP firmware if it is not already running.
It will open and map in the existing firmware if it is running.
Creation Methods Info
⚙️ Handling Errors
⚙️ Helper Functions
⚙️ Object Cleanup
axis-config-ampfault.cs, axis-config-hardware-limits.cs, axis-config-phantom-axis.cs, axis-config-settling.cs, axis-config-stop-rate.cs, axis-config-userunits.cs, axis-homing-akd-drive.cs, axis-homing-ds402-drive.cs, axis-homing-master-based.cs, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, axis-motion-hold-via-position.cs, axis-motion-modify.cs, axis-motion-point-to-point.cs, axis-motion-streaming-pt-whilestopping.cs, axis-motion-streaming-pt.cs, axis-motion-streaming-pvajt.cs, axis-motion-streaming-pvt.cs, axis-motion-velocity-via-analoginput.cs, axis-status.cs, camming.cs, compensator-1d.cs, compensator-2d.cs, compensator-single-axis.cs, error-logs.cs, gcode-motion.cs, gcode-units.cs, gearing.cs, io-dedicated.cs, io-general-purpose.cs, io-iopoint-user-buffer.cs, io-iopoint.cs, io-network-pdo-sdo.cs, io-sync-outputs.cs, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, mathblock-pdo-copy.cs, multiaxis-motion-point-to-point.cs, multiaxis-motion-velocity.cs, path-3d-points.cs, path-motion.cs, path-setup-gantry.cs, recorder.cs, touch-probe.cs, userlimit-command-position-direct.cs, userlimit-digital-input-one-condition.cs, userlimit-digital-input-two-condition.cs, userlimit-estop-store-position.cs, userlimit-feedrate.cs, and userlimit-position-abort.cs.
