◆ AxisCountSet() [1/2]
void AxisCountSet ( int32_t axisCount)
AxisCountSet will configure the number of axes processed by the controller. This overload also sets the number of allocated/enabled MotionSupervisors, Filters, and Motors.
axisCountA int32_t value to set AxisCount to.
Part of the Information method group.
Axis: Configuration
// add phantom axis
// get phantom axis
AxisCountGet
