◆ RSIAxisAddressType
enum class RSIAxisAddressType
strong
Enumerator
RSIAxisAddressTypeACTUAL_POSITION
Actual Position.
RSIAxisAddressTypeCOMMAND_POSITION
Command Position.
RSIAxisAddressTypePOSITION_ERROR
Position Error.
RSIAxisAddressTypeACTUAL_VELOCITY
Actual Velocity.
RSIAxisAddressTypeCOMMAND_VELOCITY
Command Velocity.
RSIAxisAddressTypeCOMMAND_ACCELERATION
Command Acceleration.
RSIAxisAddressTypeSTATUS
Per-axis status word. Bit definitions: RSIFirmwareStatus.
RSIAxisAddressTypeMOTION_STATUS
Motion supervisor status word. Bit definitions: RSIFirmwareStatus.
RSIAxisAddressTypeDEMAND
Filter Output (the commanded torque sent to the drive).
RSIAxisAddressTypeDIGITAL_OUTPUTS
Digital Output (general purpose).
RSIAxisAddressTypeDIGITAL_INPUTS
Digital Input (general purpose).
RSIAxisAddressTypeDEDICATED_OUTPUTS
Dedicated Outputs (Amp Enable, Brake, etc).
RSIAxisAddressTypeDEDICATED_INPUTS
Dedicated Inputs (Home, Limits, Amp Fault, etc).
RSIAxisAddressTypeMOTION_ID
The executing Motion Identifier.
RSIAxisAddressTypeMOTION_ELEMENT_ID
The executing Motion Element Identifier (element within the motion).
RSIAxisAddressTypeENCODER_PRIMARY
Primary Encoder position.
RSIAxisAddressTypeENCODER_SECONDARY
Secondary Encoder position.
RSIAxisAddressTypeFILTER_GAIN_KP
Proportional Gain.
RSIAxisAddressTypeENCODER_PRIMARY_DELTA
Primary Encoder position delta.
RSIAxisAddressTypeENCODER_SECONDARY_DELTA
Secondary Encoder position delta.
RSIAxisAddressTypeFILTER_SMOOTHED_VELOCITY
Smoothed velocity estimate from the filter object.
RSIAxisAddressTypeFILTER_PRIMARY_POINTER
Filter Primary Pointer for Gantry use.
RSIAxisAddressTypeFILTER_SECONDARY_POINTER
Filter Secondary Pointer for Gantry use.
RSIAxisAddressTypeFILTER_PRIMARY_COEFF
Filter Primary Coefficient for Gantry use.
RSIAxisAddressTypeFILTER_SECONDARY_COEFF
Filter Secondary Coefficient for Gantry use.
RSIAxisAddressTypeFILTER_VELOCITY_POINTER
Filter Velocity Pointer (points to feedback delta).
RSIAxisAddressTypeAXIS_LINK
Axis Link for Gantry use.
RSIAxisAddressTypeDEMAND_PRIMARY_OUTPUT
Motor Config Demand Output Channel 0. Useful for Created Axes.
RSIAxisAddressTypeENCODER_PRIMARY_POINTER
Encoder[0].Ptr. Useful for Created Axes.
RSIAxisAddressTypeDEMAND_CHANNEL_ONE_OUTPUT
Motor Config Demand Output Channel 1.
RSIAxisAddressTypeDEMAND_CHANNEL_TWO_OUTPUT
Motor Config Demand Output Channel 2.
RSIAxisAddressTypeDEMAND_CHANNEL_THREE_OUTPUT
Motor Config Demand Output Channel 3.
RSIAxisAddressTypeDEMAND_PRIMARY_INPUT
Motor Config Demand Input Channel 0.
RSIAxisAddressTypeDEMAND_CHANNEL_ONE_INPUT
Motor Config Demand Input Channel 1.
RSIAxisAddressTypeDEMAND_CHANNEL_TWO_INPUT
Motor Config Demand Input Channel 2.
RSIAxisAddressTypeDEMAND_CHANNEL_THREE_INPUT
Motor Config Demand Input Channel 3.
RSIAxisAddressTypeCONTROL_MODE_PRIMARY_MAP
0xFFFFxxxx. xxxx=FFF0 for 1, FF10 for 2, F210 for 3, and 3210 for 4 Demand Channel(s) Processed.
RSIAxisAddressTypeAXIS_CONFIG_FEEDBACKPTR_ZERO
AxisConfig FeedbackPtr[0].
RSIAxisAddressTypeAXIS_CONFIG_FEEDBACKPTR_ONE
AxisConfig FeedbackPtr[1].
RSIAxisAddressTypeTARGET_FEEDRATE
Target FeedRate.
RSIAxisAddressTypeTC_ACTUAL_POSITION
(internal) Trajectory Calculator Actual Position
RSIAxisAddressTypeTC_COMMAND_POSITION
(internal) Trajectory Calculator Command Position
RSIAxisAddressTypeMOTOR_DATA_STATUS
Motor dedicated limit status (9-bit bitmask). Bit 0: AMP_FAULT, 1: WARNING, 2: ENCODER_FAULT, 3: ERROR_LIMIT, 4: TORQUE_LIMIT, 5: NEG_LIMIT, 6: POS_LIMIT, 7: SOFT_NEG_LIMIT, 8: SOFT_POS_LIMIT. NOT RSIFirmwareStatus bits.
RSIAxisAddressTypeCOMPENSATION_CURRENT_VALUE
Compensation value, where multiple compensators can write.
RSIAxisAddressTypeCOMPENSATION_FINAL_VALUE
Final Compensation value, the value subtraced from ActualPosition and added to position demand.
RSIAxisAddressTypeBACKLASH_VALUE
The resuling backlash compensation value.
RSIAxisAddressTypeTARGET_POSITION
Target Position.
RSIAxisAddressTypeDEDICATED_INPUTS_POINTER
Pointer to Dedicated Inputs (Home, Limits, Amp Fault, etc).
RSIAxisAddressTypeAMP_ACTIVE_SUPPORTED
Will be automatically set true for drives which support AMP_ACTIVE (read-only).
RSIAxisAddressTypeDS402_SUPPORTED
Will be automatically set true for drives which support the DS402 standard.
RSIAxisAddressTypeDEMAND_PRIMARY_SCALE
Motor Config Demand Scale Channel 0.
RSIAxisAddressTypeDEMAND_CHANNEL_ONE_SCALE
Motor Config Demand Scale Channel 1.
RSIAxisAddressTypeDEMAND_CHANNEL_TWO_SCALE
Motor Config Demand Scale Channel 2.
RSIAxisAddressTypeDEMAND_CHANNEL_THREE_SCALE
Motor Config Demand Scale Channel 3.
RSIAxisAddressTypeFRAME_INDEX
The index of the frame currently executing.
RSIAxisAddressTypeFRAME_LOAD_INDEX
The index of the last loaded frame.
RSIAxisAddressTypeAMP_ENABLE_AMP_FAULT_TIMEOUT
The timeout in seconds after which an Amp Fault will occur if the Axis does not enable after calling AmpEnableSet(true).
RSIAxisAddressTypePOST_TRAJECTORY_GEARING_POSITION
The gear position applied to this axis by Post Trajectory Gearing.
RSIAxisAddressTypeCURRENT_FEEDRATE
Current FeedRate.
calculate-acceleration-from-velocity.cpp, difference-of-position-user-limit.cpp, mathblock-calculate-acceleration-from-velocity.cs, mathblock-difference-of-position-userlimit.cs, recorder.cs, userlimit-command-position-direct.cs, userlimit-estop-store-position.cs, userlimit-feedrate.cs, and userlimit-position-abort.cs.
Definition at line 451 of file rsienums.h.
