const int DIGITAL_INPUTS_PDO_INDEX = 3;
if (controller.NetworkStateGet() !=
RSINetworkState.RSINetworkStateOPERATIONAL)
controller.Delete();
Set the motion hold type.
RSIMotionAttrMask
RSIMotionHoldType
