◆ MotionAttributeMaskOnSet()
void MotionAttributeMaskOnSet ( RSIMotionAttrMask maskOn)
MotionAttributeMaskOnSet turns on a particular motion attribute mask.
maskOn::RSIMotionAttrMask value we want to turn on.
Motion: Hold
// configure axis
// enable motion hold
axis.MoveRelative(3);
// disable motion hold
Definition rsi.h:6515
Set the motion hold type.
Definition rsienums.h:617
RSIMotionAttrMask
Definition rsienums.h:1144
RSIMotionHoldType
Definition rsienums.h:1179
::RSIMotionAttrMask, MotionAttributeMaskOnGet, MotionAttributeMaskOffSet
MotionHoldReleasedBySoftwareAddress.cpp, MultiaxisMotion.cpp, axis-motion-hold-via-address.cs, axis-motion-hold-via-digitalinput.cs, and axis-motion-hold-via-position.cs.
