◆ ServiceChannelWrite() [2/3]
void ServiceChannelWrite ( int32_t index,
int32_t subIndex,
int32_t byteCount,
int32_t sdoValue,
uint32_t timeoutMilliseconds = SDOTimeoutMillisecondsDefault )
Write a number to the SDO. The index, subIndex, byteCount, and valid numeric values are drive specific. Refer to the drive manual to determine these values.
indexThe memory address to write to
subIndexThe sub index to write to
byteCountThe number of bytes to write
sdoValueThe numeric value to write
timeoutMillisecondsThe time in ms used in two ways: first as the wait for the service channel to become available (a previous operation, possibly from another process, may still be in progress), then as the wait for the write response. Each wait generates a timeout error if exceeded, so a call can take up to twice this value before erroring. (Default: SDOTimeoutMillisecondsDefault)
Axis: Homing
/* This sample application demonstrates drive-based homing with a DS402-compliant drive using the RapidCode .NET API.
Drive-based homing avoids network latencies since the drive executes the homing routine.
Many drives follow the DS402 standard, making this a widely applicable homing method.
This sample configures SDO parameters, manages control word states, and monitors status word for completion.
Console.WriteLine("📜 Axis Homing: DS402 Drive");
const int offsetIdx = 0x607C;
const int offsetSub = 0x0;
const int offsetSize = 4;
const int offsetVal = 0;
const int methodIdx = 0x6098;
const int methodSub = 0x0;
const int methodSize = 1;
const int methodVal = 24;
const int targetSpeedIdx = 0x6099;
const int targetSpeedSub = 0x1;
const int targetSpeedSize = 4;
const int targetSpeedVal = 2;
const int originSpeedIdx = 0x6099;
const int originSpeedSub = 0x2;
const int originSpeedSize = 4;
const int originSpeedVal = 10;
const int accelIdx = 0x609A;
const int accelSub = 0x0;
const int accelSize = 4;
const int accelVal = 100;
const int CTRL_WORD_PREP_HOMING = 15;
const int CTRL_WORD_START_HOMING = 31;
const int DELAY_MS = 20;
const int STATUS_TARGET_REACHED = 0x400; // bit 10: target reached (homing complete)
const int STATUS_HOMING_ATTAINED = 0x1000; // bit 12: homing attained (successful)
const int STATUS_HOMING_ERROR = 0x2000; // bit 13: homing error
// get rmp controller
// 1. configure homing parameters via SDOs writes
axis.NetworkNode.ServiceChannelWrite(offsetIdx, offsetSub, offsetSize, offsetVal); // home offset
axis.NetworkNode.ServiceChannelWrite(methodIdx, methodSub, methodSize, methodVal); // home method (home type)
axis.NetworkNode.ServiceChannelWrite(targetSpeedIdx, targetSpeedSub, targetSpeedSize, targetSpeedVal); // speed during search for switch
axis.NetworkNode.ServiceChannelWrite(originSpeedIdx, originSpeedSub, originSpeedSize, originSpeedVal); // speed during search for zero
axis.NetworkNode.ServiceChannelWrite(accelIdx, accelSub, accelSize, accelVal); // home acceleration
// 2. configure control word for homing
int axisCtrlWordIdx = (int)axis.NetworkIndexGet(RSINetworkIndexType.NetworkIndexTypeCONTROL_WORD_INDEX);
axis.rsiControl.NetworkOutputOverrideValueSet(axisCtrlWordIdx, CTRL_WORD_PREP_HOMING); // control word should be 15 before switching to homing mode
axis.rsiControl.NetworkOutputOverrideSet(axisCtrlWordIdx, true); // override control word
controller.SampleWait(DELAY_MS); // delay to give transitions time
// 3. configure operation mode to homing
axis.OperationModeSet(RSIOperationMode.RSIOperationModeHOMING_MODE);
// 4. home
axis.rsiControl.NetworkOutputOverrideValueSet(axisCtrlWordIdx, CTRL_WORD_START_HOMING); // start homing
bool cancelHome = false;
UInt16 statusWord = axis.NetworkNode.StatusWordGet(Constants.AXIS_0_INDEX);
while ((!cancelHome) && ((statusWord & STATUS_TARGET_REACHED) == 0)) // wait until target reached or cancel
// A timeout that sets cancelHome would be a good idea for this while loop
statusWord = axis.NetworkNode.StatusWordGet(Constants.AXIS_0_INDEX); // update status word
// A short sleep or wait is appropriate so you aren't spamming this call
// evaluate homing result
if ((statusWord & STATUS_HOMING_ATTAINED) == STATUS_HOMING_ATTAINED)
Console.WriteLine("Axis homed successfully");
else if ((statusWord & STATUS_HOMING_ERROR) == STATUS_HOMING_ERROR)
Console.WriteLine("Error occurred during homing");
// clean up
axis.rsiControl.NetworkOutputOverrideSet(axisCtrlWordIdx, false);
// restore mode of operation to your desired control mode (typically CSP mode)
axis.OperationModeSet(RSIOperationMode.RSIOperationModeCYCLIC_SYNCHRONOUS_POSITION_MODE);
Set the axis operation mode.
NetworkNode * NetworkNode
Definition rsi.h:6545
Definition rsi.h:6515
Sets a PDO output directly.
void ServiceChannelWrite(int32_t index, int32_t subIndex, int32_t byteCount, int32_t sdoValue, uint32_t timeoutMilliseconds=SDOTimeoutMillisecondsDefault)
Write a number in the SDO.
Get the DS402 status word.
MotionController * rsiControl
Definition rsi.h:4989
Definition rsienums.h:617
RSIOperationMode
DS402 modes of operation.
Definition rsienums.h:1415
RSINetworkIndexType
Definition rsienums.h:1513
axis-homing-ds402-drive.cs.
