◆ MoveTrapezoidal() [2/3]
void MoveTrapezoidal ( double position,
double vel,
double accel,
double decel )
MoveTrapezoidal commands a point-to-point motion with a trapezoidal velocity profile. This has a trapezoidal shape for the velocity with constant acceleration and deceleration phases.
positionTarget Position in units.
velMaximum velocity, units/second.
accelMaximum acceleration , units/second/second.
decelMaximum deceleration , units/second/second.
AbsoluteMotion
axis.MoveTrapezoidal(POSITION, VELOCITY, ACCELERATION, DECELERATION);
Go to Axis->Motion (default tab)
Motion Scope:
Trapezoidal Move profile shown below:
Point to Point, MoveSCurve, MoveRelative, MoveVelocity, MovePT, MovePVT
axis-motion-point-to-point.cs, and point-to-point.cpp.
