◆ SoftwarePosLimitActionGet()
RSIAction SoftwarePosLimitActionGet ( )
SoftwarePosLimitActionGet returns the action that will occur when the Software Positive Limit Event triggers.
(::RSIAction) Action taken on Limit trigger.
Note:
Axis: Configuration
// add phantom axis
// get phantom axis
Go to axis screen->Limits & Actions. In image below, SoftwarePosLimitActionGet returns the action type shown in the Positive (+) Software box. It is currently set to E_STOP.
