◆ HomeDecelerationGet()
double HomeDecelerationGet ( RSIHomeStage homeStage = RSIHomeStage::RSIHomeStageSTAGE_ONE)
The only situation HomeDeceleration is used is if the maximum homing travel is exceeded and a switch is never hit. StopTimeSet() is used for the pos/neg limit switch.
homeStageOptional (Default: RSIHomeStageSTAGE_ONE)
(double) decel units/second/second.
Axis: Homing
// get rmp controller
// configure limit action
// execute homing routine
axis.Home();
// clean up
Set the slow home velocity.
Execute the homing routine.
Set the home velocity.
bool HomeStateGet()
Get the home state.
Definition rsienums.h:621
Definition rsienums.h:1256
Home
Master-based homing diagrams.
