◆ MoveVelocity() [2/2]
void MoveVelocity ( double velocity,
double accel )
MoveVelocity command a constant velocity move (jog). The axis will accelerate to the Target velocity and continue indefinitely.
velocityTarget velocity, units/second.
accelMaximum acceleration, units/second/second.
MoveVelocity
axis.MoveVelocity(VELOCITY, ACCELERATION); // move at constant velocity
Motion Scope:
Velocity move (Trapezoidal type - 0% jerk) profile shown below:
Velocity Motion, MoveSCurve, MoveTrapezoidal, MovePT, MovePVT
