11.1.1
ClearFaults()
void ClearFaults
ClearFaults will clear all the faults for an
or
MultiAxis
, particularly when it is in an ::RSIStateERROR state.
Action
if
(axis->StateGet() ==
RSIStateERROR
axis->ClearFaults();
RSI::RapidCode::RSIState::RSIStateERROR
@ RSIStateERROR
Error.
Definition
rsienums.h:1021
When called on a single
, ClearFaults will also attempt to clear any Node status, and clear any feedback faults if necessary.
Go to axis screen->
Status. ClearFaults is shown in image below.
StateGet
SourceGet
MotionHoldReleasedBySoftwareAddress.cpp
MultiaxisMotion.cpp
PVTmotionMultiAxis.cpp
PathMotion.cpp
SingleAxisSyncOutputs.cpp
SyncOutputWithMotion.cpp
UpdateBufferPoints.cpp
_helpers.cs
axis-homing-akd-drive.cs
axis-motion-point-to-point.cs
basic-template.cs
calculate-acceleration-from-velocity.cpp
difference-of-position-user-limit.cpp
gcode-motion.cs
gcode-units.cs
multiaxis-motion-point-to-point.cs
multiaxis-motion-velocity.cs
path-3d-points.cs
path-motion.cs
path-setup-gantry.cs
point-to-point.cpp
userlimit-command-position-direct.cs
userlimit-estop-store-position.cs
, and
userlimit-position-abort.cs
RapidCodeMotion
1.15.0
