SyncInterruptEnableSet sets controller interrupt generation on or turns them off. SyncInterrupts are designed to wake a task to allow for any host processing that needs to take place at the start of the controller's sample rate cycle.
enable
True = Controller Interrupts will be generated. False = They will not be generated.
We plan to use the Sync interrupt with this application.
// -- C++ -- //
// -- C# -- //
controller.SyncInterruptEnableSet(true);
Most interrupts for the controller are used directly from the Axis and MultiAxis classes. The Sync Interrupt is typically the only controller-specific interrupt. The Sync Interrupt is only for use with real-time operating systems.
