◆ InterruptWait()
RSIEventType InterruptWait ( int32_t milliseconds)
inherited
InterruptWait suspends the current thread until an interrupt arrives from the controller. This is commonly used while waiting for specific interrupts such as Motion Done, velocity reached, or recorder done. Please see ::RSIEventType for options. You can specify an extact wait time or use ::RSIWait.
millisecondsMilliseconds to wait -or- an ::RSIWait value to return immediately or wait forever.
(::RSIEventType) Event which takes place or RSIEventTypeTIMEOUT event after time elapses.
IO: User Limits
Console.WriteLine("šŸ“œ User Limit: Command Position Direct Set");
const int DURATION = 0;
// configure user limits
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ FIRST USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_FIRST,
conditionNumber: 0,
actionAxis: axis.NumberGet(),
duration: DURATION,
singleShot: ONE_SHOT);
ā”Œā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”
│ SECOND USER LIMIT │
ā””ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”˜
number: USER_LIMIT_SECOND,
conditionNumber: 0,
userLimitMask: 1,
limitValueUInt32: 1);
conditionNumber: 1,
limitValueDouble: 0.0);
actionAxis: 0,
duration: 0,
// start motion
axis.ClearFaults();
axis.Abort();
axis.ClearFaults();
Console.WriteLine($"āŒ Error: {e.Message}");
number: userLimitIndex,
bool done = false;
int interruptCount = 0;
while (!done)
interruptCount++;
switch (eventType)
done = true;
Console.WriteLine($"\nāœ“ Completed - received {interruptCount} interrupts");
default:
NetworkNode * NetworkNode
Definition rsi.h:6545
Definition rsi.h:6515
int32_t NumberGet()
Get the axis number.
RSIEventType
Event Types or Status Bits.
Definition rsienums.h:1045
RSIUserLimitLogic
Definition rsienums.h:717
Definition rsienums.h:1199
Definition rsienums.h:447
Trigger types for UserLimits.
Definition rsienums.h:704
InterruptWait will return logged Interrupts until there are none in the FIFO buffer. Then it begin waiting with a timeout for the next.
RapidCodeMotion::InterruptEnableSet, MotionController::InterruptEnableSet, RapidCodeMotion::InterruptWake, MotionController::InterruptWake
