◆ RSIEventType
enum class RSIEventType
strong
Enumerator
RSIEventTypeINVALID
RSIEventTypeNONE
RSIEventTypeAMP_FAULT
RSIEventTypeAMP_WARNING
RSIEventTypeFEEDBACK_FAULT
RSIEventTypeLIMIT_ERROR
RSIEventTypeLIMIT_TORQUE
RSIEventTypeLIMIT_HW_NEG
RSIEventTypeLIMIT_HW_POS
RSIEventTypeLIMIT_SW_NEG
RSIEventTypeLIMIT_SW_POS
RSIEventTypeMOTION_DONE
RSIEventTypeMOTION_START
RSIEventTypeMOTION_MODIFY
RSIEventTypeMOTION_AT_VELOCITY
RSIEventTypeMOTION_OUT_OF_FRAMES
RSIEventTypeMOTION_LOAD_FRAMES
RSIEventTypeNEAR_TARGET
RSIEventTypeSETTLED
RSIEventTypeAT_TARGET
RSIEventTypeFRAME
RSIEventTypeRECORDER_HIGH
RSIEventTypeRECORDER_FULL
RSIEventTypeRECORDER_DONE
RSIEventTypeSEQUENCE
RSIEventTypeSEQUENCE_LOAD
RSIEventTypeCONTROL_HOST_PROCESS_TIME_EXCEEDED
RSIEventTypeCONTROL_FAN
RSIEventTypeSYNQNET_DEAD
RSIEventTypeSYNQNET_RX_FAILURE
RSIEventTypeSYNQNET_TX_FAILURE
RSIEventTypeSYNQNET_NODE_FAILURE
RSIEventTypeSYNQNET_RECOVERY
RSIEventTypeSQNODE_IO_ABORT
RSIEventTypeSQNODE_NODE_DISABLE
RSIEventTypeSQNODE_NODE_ALARM
RSIEventTypeSQNODE_ANALOG_POWER_FAULT
RSIEventTypeSQNODE_USER_FAULT
RSIEventTypeSQNODE_NODE_FAILURE
RSIEventTypeSQNODE_IO_FAULT
RSIEventTypeUSER_LIMIT
RSIEventTypeCAPTURE
RSIEventTypeSYNC_GROUP_FAULT
EtherCAT sync group (containing the Axis's node) is DEGRADED or ABSENT. Fires once per fresh fault; configure the axis action with Axis::SyncGroupFaultActionSet. See Sync Groups.
RSIEventTypeHOME
RSIEventTypeTIMEOUT
ControllerInterrupts.cpp, axis-motion-point-to-point.cs, axis-status.cs, userlimit-command-position-direct.cs, userlimit-digital-input-one-condition.cs, userlimit-digital-input-two-condition.cs, userlimit-estop-store-position.cs, and userlimit-position-abort.cs.
Definition at line 1102 of file rsienums.h.
